Yellowing Headlights
I just bought a '95 240 se and the headlights are yellowish. Every 240 from this year i've seen has the same problem. Is there any way to fix this? Or is this from the plastic degrading? If there's not a way, can anyone suggest an aftermarket brand that looks good and won't turn yellow.
TIA
T.H.T.G.
TIA
T.H.T.G.
My headlights were the same way, i found that if you spray some engine degreaser on the headlights and then wipe it cean before the degreaser touches the paint. You can also use the degreaser with a scrub brush if there really bad.
Did you spray the degreaser on the outside? cuz the discoloration looks like it is inside of the casing, and it looks like the previous owner let moisture into the headlight and now it looks like crap. but the driverside light looks brand new.
tantrumS13
Dec 17, 2002 07:42 PM
