Cold Hard start
Old Nov 29, 2008 | 06:33 AM
ah thats what you were talking about when you said DVOM never heard anyone call it that when i went to Honda school all the books called it a DMM (Digital Multi Meter) anyway yea i have a Fluke 88. ill test it out today
Old Dec 12, 2008 | 08:53 AM
still havnt figured it out... frustrates me i checked codes again and i keep getting a 55 which means everything is fine... i unplugged the ect sensor while it was running and i got a code 13 which is a ect code but nothing else.
also code 55 basicly means nothing is unplugged cause it would tell me which clears up one of my worries i thought i left something unplugged.
now i have to figure out what it is, i cant even go anywhere w/o my other battery for fear of my car not starting before the battery dies.
oh here another hint if it can help anyone figure this out when im having a hard time starting it i smell gas, so now im wondering if its too rich while its starting or its not sparking. now why would outside temperature affect these two possibilities.... man i swear if it was someone elses car i woulda figured it out already.
oh one other thing i replaced all the rubber fuel hoses going from hard line to motor i dont think i got exact factory size but it seals would that make a problem?
Old Dec 13, 2008 | 06:58 AM
well i changed out the ECT sensor with one from a 91-94 sentra SE-R they had it in stock $15 so i got it. didnt seem to be the problem... but the more i think about it the more i think its the injector seals. i mean i dont think anything else like that would go bad from just sitting there other then seals.
anyway i had bought new seals for my new injectors so ill just put them on my stock injectors let it sit over night see if thats it.
Old Dec 16, 2008 | 11:30 AM
by chance have you done a compression test? i know it sounds a bit pointless but i'm curious if there is enough of a difference in compression when the engine is cold and at normal operating temp. also could you specify "cold".
i'm still under the impression that you have a leaky injector. it's happened to be before with all the same sympathy with three different cars.
Old Dec 16, 2008 | 07:56 PM
yea i think so too im pretty sure compression is fine it never had a problem starting b4 i let it sit for over a year dont think compression would have changed
Old Jan 3, 2009 | 09:45 PM
FuriousZ's Avatar
Did you fix the starting problem?
Old Jan 5, 2009 | 01:33 AM
not yet i will be swapping out injectors with known good ones soon maybe next week then ill go from there if that dosnt solve my problem
Old Jan 18, 2009 | 02:55 PM
ok here is where i am at so far and im close to finding the problem. i put known good injectors not the problem and i put in a sard FPR and its not the problem.
hmm i installed my FPR with a guage and well its not the FPR cause ill let the car run then ill let it sit and ill check the guage and see the fuel pressure dropping slowly. i let the car run turned it off and the guage read 30psi i pulled out my radio put in a new one wired up 2 new speakers took me about 30min and i checked the guage again and it was at 10 psi...i set it to 43 psi with the vacuum hose disconnected btw
so yea where else can i lose pressure from? fuel pump? fuel lines? thing is i never see my car leaking anything.
also something i found peculiar was that the rubber pressure hose from fuel filter to fuel rail reaked of gasoline and nothing else around it did. maybe that line wasnt designed for fuel injection and its too porous. i didnt use factory lines because they were hard and brittle anyway ill change lines tomorrow and see if that helps any.
Old Jan 18, 2009 | 08:00 PM
shaban's Avatar
It doesn't get cold in Miami
Old Jan 18, 2009 | 11:23 PM
lol ah thats why my SR is acting up its like wtf its January and its effing 90 degrees out..
Old Jan 20, 2009 | 07:27 PM
  #26
allan's Avatar
quite possibly the fuel pump could be going...
mine starts really slow specially in the winter,my neighbor with a 180 like mines does the same thing.
Old Jan 24, 2009 | 11:26 AM
  #27
FINALLY update i found the problem.... its the timing on the crank angle sensor.... wtf how come no one mentions this on forums ive looked though so many forums. anyway im so happy lol!.
Old Jan 24, 2009 | 09:35 PM
  #28
good to hear you figured it out. but when you say that is was the cas, what exactly do you mean? the only thing that i could think of to cause this problem under the described circumstances would be a cracked cover or broken water seal.
Old Jan 25, 2009 | 01:28 AM
  #29
no the ignition timing was off i just did this and it was ok
http://srownersclub.com/faq/index.asp#startup
70Challenger
Mar 28, 2006 10:18 PM
v8killa
Jan 13, 2006 10:14 AM
SexyDRIFT
Dec 3, 2005 09:08 AM
sirenx
Oct 17, 2005 04:30 PM
s14 rb25det
Sep 27, 2004 09:17 AM
