sr bogging down at low rpm's
ok so my problem is that i just finished putting my sr back in after doing some simple maintenence to it over the winter and it starts up fine but when i drive it it starts to stutter and bog down really bad at around 4 grand which is right when it starts to build boost... now this problem only happens under normal driving.. if i accelerate hard it is fine and has no stuttering but since that is bad on gas id like to fix it : ).... so if anyone has any suggestions id really like to know thanks...
last year i ran it basically all stock.. all it had was full exhaust and a front mount.. i took it out to fix a freeze plug that fell out of the back of the head and replace some coolant hoses. The only thing i did different this time was put on a aftermarket intake manifold.. Ive never had this problem before but i will check the TPS and timing... im pretty sure all my sensors and grounds are good so hopefully it is something simple.. thanks
the manifold is a cheap ebay one that copied greddy... but anyway i fixed the problem.. over the winter i pulled off the TPS to clean the throttle body and must have put it back on at the wrong angle cause last night i tilted it all the way down and turns out that was the only problem and the car runs fine now... thanks for the help
BlackZenki82
SR
Jun 5, 2009 09:08 AM
