SR Head gasket
Old Apr 20, 2007 | 08:23 PM
SR Head gasket
never done a nissan head gasket was just wondering if there was anything special i should look out for when i pull my SR head off.
ive done a bunch of honda heads lots of 3.2-3.5 v6 heads and k20 and k24 heads and the sr seems simple but just wana know if theres anything special to look outfor so i dont break it lol
Old Apr 20, 2007 | 08:27 PM
you know the usual, just follow the Factory removal procedure to break the bolts free and remove the head. Becareful with the butter soft aluminium.
.....yeah and your gonna have to fully dismantle the valvetrain to get the head off, thats such a bummer. Other than that it should be cake for you.
Old Apr 21, 2007 | 09:14 AM
Durdan's Avatar
dismantle the valvetrain and keep everything in order!!!
there are little shims that need to be removed on the top of each valve spring. do not get these out of order.
dont forget to put the two long gold 10mm bolts back in (inside the chain area) before you put the cams back in.
dont forget your torque procedure for the head
pay attention to TDC and cam timing. set the motor at TDC before disassembly. TDC is 2nd mark from the left on the crank pulley and cam lobes facing out. pull the valve cover and note the position of the cam gears in relation to the amount of chain links/pins. this isnt like a honda where each gear has a mark that coresponds with the other gear. DO NOT GO BY THE SHINY LINKS!!! go by chain link count!
this is what i drew up. live it. learn it. love it.
Old Apr 21, 2007 | 10:06 AM
some ****ing badass artwork Taylor
what happens if our lil shim buddies are out of order?
and whats the proper orientation of those guys? some have the groove some dont
Old Apr 21, 2007 | 03:36 PM
thanks man that helped alot lol i dont wana **** up the timing >.<
Old Apr 22, 2007 | 06:43 AM
Durdan's Avatar
the shims are matched pairs. if mixed up, they can cause as little of an effect as valvetrain noise, and as bad as rocker arm failure.
its also easy to know the orientation (groved or flat) bc the rocker arm is notched for the grooved one.
BUT, if you start off laying the valvetrain out on a table in the same manor it was sitting in the head, then you shouldnt have a problem!
do it once, do it right.
Old Apr 30, 2007 | 12:16 PM
CharlesJ's Avatar
Club240 Staff
Also a good idea to replace your head bolts or go to ARP studs
Old May 1, 2007 | 01:08 AM
yea, unless ur doing crazy motor work i would recommend using oem head studs that way you dont have to take it apart and re-torque them again
Old May 1, 2007 | 07:57 AM
...and it might not be a bad idea to have the head milled to ensure a better seal once it is all done. It's not mandatory but hey, it dosen't hurt.
Old May 1, 2007 | 03:21 PM
Durdan's Avatar
not milled... just resurfaced. big difference
Old May 1, 2007 | 04:01 PM
yea whoops i meant resurfaced
didnt realized what i typed.
Resurfacing is only like $50-60
70Challenger
Jun 25, 2006 02:28 PM
89180sx
Jul 15, 2003 01:57 PM
Monkey Force
May 31, 2003 01:00 AM
roadkill669
Apr 9, 2003 07:18 AM
konseiEva
Nov 9, 2002 02:23 PM
