NEED HELP with Heater Core Coolant Hoses
Old 03-10-2009, 09:40 AM
bestint's Avatar
Arrow NEED HELP with Heater Core Coolant Hoses
had to tow my car back to the shop last night because some of my lines for the heater core busted. they were old and all crusty. now i need to get new hoses but i dont know where to start. all i could find is samco hoses or the like but for radiator hoses (upper, lower) or cheap ebay silicone hoses that come with everything but i dont know if i can trust it.
im thinking theres gotta be oem part numbers or samco part numbers that everyone uses to replace those hoses but cant seem to find it on zilvia or the web. i want to replace all of them. theres like a good 5-7 of them. still working on a couple that are hard to reach.
i need suggestions on what i could do right now. what are my options? thanks in advance.
its a SR S13 blacktop in a S14 zenki
here's some pics of the hoses that leaked out.
bestint is offline
Old 03-10-2009, 09:57 AM
bestint's Avatar
here some more pics...
these are the hoses i took off, they're all in pretty bad shape so i want to change them all out. i wanted to get a samco hose kit but they dont have one for the SR. alli found was cheap eBay knock offs.
then i found these, but i dont understand how i would use them.
http://enjukuracing.com/heater-hoses...et-p-6500.html
does using that eliminate the little hoses? if someone could explain, please help.
bestint is offline
Old 03-10-2009, 02:16 PM
FuriousZ's Avatar
MY two cents:
The hoses you removed are still coolant hoses but not necessarily heater hoses, you removed them from under the intake plenum.
The heater hoses just connect to the heater core in the fire wall and are the ones from the enjukuracing.com link.
I would just go to an auto parts store and buy the short hoses and replace those. And if you really need the "heater hoses" in the back, then I would buy those from the enjukuracing.com link.
FuriousZ is offline
Old 03-10-2009, 02:29 PM
bestint's Avatar
im told that the diameter of the usdm and jdm pipes are different so that even after i replace the hoses with usdm sizes, they will eventually burst again.
bestint is offline
Old 03-10-2009, 06:37 PM
positron's Avatar
Check page 16 post#237 on this thread https://www.s-chassis.com/forums/sho...=42547&page=16 I replaced those hoses with ones from the parts store, maybe the part numbers will be helpful to you.
positron is offline
Old 03-10-2009, 07:07 PM
sounds like someone told you wrong. there is no such thing as usdm or jdm diameters, it's metric or sae.
jramosthe1st! is offline
Old 03-10-2009, 09:43 PM
240smoke's Avatar
HAHA, OWNED!!!! I bought the kit from www.frsport.com and everything fit fine.
240smoke is offline
Old 10-08-2010, 03:30 PM
bestint's Avatar
thank you. that helped. took the hoses and they helped me find simular ones.
bestint is offline
nvrstock
10-25-2005 03:59 AM
TWong1200
09-20-2005 09:22 PM
kang128
06-08-2005 11:15 PM
seany1
05-02-2005 01:32 PM
s13_bb2.
11-23-2003 07:54 AM
Quick Reply: NEED HELP with Heater Core Coolant Hoses
