300z brake upgarde
Originally posted by war
so i guess my next question would be how much harder is it to do the rear?
would the Z axels fit on a 240? I mean are they long enuff? I kno the LSD'll fit in, which is also wut Im salvaging from my Z... but is it possible to use the Z axels? or could I reuse my S14 axels?
And, you don't need to swap over EVERYTHING to get the benefits of rear Z brakes. The calipers and rotors will bolt to the S rear spindles. If you're 4 lug, you'll need to modify the rotors to accept the 4 lug pattern. And, the calipers bolt right up. Now, if you want to keep an e-brake, thats an entirely different story.
How did you install your Ebrake cable? I did a rear Z32 with ebrake conversion on S14. Now i have a problem installing the ebrake cable. Does anyone has a better way to install the ebrake cable? Insteal of cutting and clip them together? Plase HLEP buntavy@yahoo.com
Wow, resurection of the dead thread, lol. Seems like you've been searching. Check forums and junkyards for the parts you need.
Originally posted by rkcarguy
You have to run the whole hub assembly from the 300ZX or Skyline. It's the easiest anyway. I used a R33 rear end and transfered the LSD, axles, hubs, and calipers all over to a 240 subframe.
front brakes just require the Z32 rotors, Calipers and Z32 to S__ brake lines...and then the removal of the dust shield.
the rears you can just bolt on the Z32 calipers, Rotors, and Z32 to S__ brake lines BUT you lose your ebrake. for the ebrake to work you need the Z32 drum brake assembly. and then you remove the dust shield.
