300z brake upgarde
Originally posted by LandHo_S13
Umm the drum brake essembly is connected to the dust shield you can trim it but it is needed.
unless you had the hubs from a S15 then you could use it. damnit why did i sell those!!
Originally posted by barrigaS14
trim remove whats the difference? you can't use it anyways.
Thats odd. I have Z32 rear hubs and it works fine.
Originally posted by rivneo1
Its true u cant fit stock s14 wheels too to Z32 brakes? I heard from somebody u cant ,sorry I haven dont that much reasearch but the little I had done ,I have find anything.
do it this way. if it fits it fits...if it doesn't it doesn't.
oh yeah duh...it was bent and we just took it off.
then what the hell did we do? ahhh who cares...
Thats the greatest motto "If it fits it fits!"
Okay so the final verdict is that you have to swap out just the Z ebrake assembly, rotors, and brakes right? I don't need a Z rear end or anything like that, right? I found a very nice set of Nissan 4 pots / 2 pots on a 300 ZX at the junk yard today. They told me $250 for all 4 brake calipers. I do need to have an e-brake, and I would like the better braking that the 4/2 pots would give me. TIA.
Booster? So just check junkyards for everything....so you just need the rotor, caliper and Z32 to S13 brake lines? I'm sort of confused about the brake line part. Could someone explain that a little more clearly?
loosenut
May 22, 2006 10:31 AM
