300zx calipers & ABS
Old Feb 25, 2003 | 07:32 PM
spitz7985's Avatar
if I put 300zx calipers up front, will I be able to retain my ABS?
Old Feb 26, 2003 | 05:26 PM
StanBo's Avatar
Re: 300zx calipers & ABS
I don't think so because there is no sensor on the brakes.
Old Mar 19, 2003 | 08:52 PM
s14det's Avatar
The ABS sensor is not on the caliper it self....
Old Mar 21, 2003 | 07:09 AM
spitz7985's Avatar
asad from freshalloy told me that you can keep the abs
Old Apr 12, 2003 | 08:32 PM
NiSmO Knight's Avatar
To do the 3Z calipers, u need new lines (u prolly already have em) and I believe u need the brake master cylinder from the Z as well to be able to provide the pressure power to use the calipers correctly... I think u can get a brake master cylinder w/ abs from a Z pretty easy, if u need Z parts, let me know
Old Apr 12, 2003 | 08:36 PM
I'm with Stupid's Avatar
You don't need the brake master cylinder from a Z the 240's will work fine.
Old Apr 12, 2003 | 09:45 PM
But then there wouldnt be enuff brake pressure to fully use the calipers in that case rite???
I know u have to upgrade the brake lines... some say get the brake master cylinder from the Z to compensate for the size difference... Is that true or the Silvia's brake master cylinder will be enuff?
Old Apr 12, 2003 | 10:11 PM
The stock master cylinder works fine. Very few people do the Z master cylinder upgrade because it's a hassle since the lines don't match up.
Old Apr 12, 2003 | 10:36 PM
Oops I'm sorry, but I'm wrong lol. You can use the master cylinder out of a Z31, Z32, or even a S12. For an S13 they all bolt in with no mods at all. The stock size is 7/8'', while the S12 and '85 Z31 are 15/16'', and the Z32 was 15/16'', 1'', and 1 and 1/16'' depending on the yr/model. For an S14 you'll have to modify the lines for any of these to work or you can get the master cylinder out of a automatic S14 which has a 15/16'' master cylinder. Hope this can clear it up cause I was pretty off.
Old Apr 12, 2003 | 10:41 PM
Soo.... since I have an auto S14, I can use that master cylinder for the 3Z calipers and rotors Im swapping in?
Old Apr 12, 2003 | 10:51 PM
Yeah, you should be fine. But just so I can smooth this out a little more... S13's with abs also had 15/16'' MC, but they don't work with non abs S13's. If you choose the S12's MC (to upgrade your S13) you need the 200sx Turbo non abs.
Old Apr 13, 2003 | 02:24 AM
{o.0}
.......... HuH????.................
Old Apr 13, 2003 | 03:24 AM
StanBo's Avatar
Originally posted by NiSmO Knight
{o.0}
S12 = 200sx
Kinematics
Jun 4, 2006 11:33 PM
wannaS15
Apr 12, 2006 05:18 PM
b0rdin4life
Feb 15, 2006 02:33 AM
hatecivics
28
Jun 1, 2005 07:30 PM
rb240sx
Jul 28, 2004 04:47 PM
