Adjustable upper pillowball mount camber question.
Old Apr 27, 2005 | 04:03 AM
KeN VeRsUs RyU's Avatar
I have the FLEX's with the adjustable mounts up front and was wondering if each notch(for camber) is equivelent to 1 degree? Right now it's pretty close to zero so does that mean it's zero degrees camber or is that just some reference number? I hope those weren't the stupidest or the most obvious questions but i just wanted to know because i'm getting my alignment done soon.
thanks for the help.
Old Apr 29, 2005 | 03:12 AM
Levi SPL S14's Avatar
just make it so that the camber adjuster hits the inside of the shock mount for awesome camber hahaha!! tis GREAT!
Old Apr 30, 2005 | 12:19 PM
Re: Adjustable upper pillowball mount camber question.
IIRC each large notch is 1 degree, but if you set the camber plates at 0 after installing the coilovers, that doesn't mean that your starting point is with the wheels at 0 degrees.
Get camber bolts, set the camber plates to 0, then get an alignment and have the shop align the front to 0. then from there you can adjust and know what angle your fronts are really at.
Old Apr 30, 2005 | 03:21 PM
^ meh i like what i said better haha
sw20fj40
Dec 23, 2005 07:38 AM
2fourDS14
Aug 31, 2005 08:34 PM
Evo3
Jan 22, 2005 08:39 PM
l2aine
Jun 1, 2004 01:10 AM
StanBo
Nov 5, 2002 03:37 AM
