AGX or tokico blue?
Old Nov 15, 2004 | 03:09 PM
jackyliem's Avatar
AGX or tokico blue?
since they are about the same price. which should I get? I know tokico is a better brand but AGX is adjustable. and what spings should I use with them?
Old Nov 15, 2004 | 03:50 PM
ArticDragon's Avatar
Most common and preferred combo AGXs with Tein S-Techs. AGXs are far better than the Tocikos because of adjustablilty.
Old Nov 15, 2004 | 07:49 PM
Wish_itwasJDM's Avatar
Dude u got to get the s.techs with the agxs. I got mine installed yesterday and it drives and look hella good!
Old Nov 15, 2004 | 10:07 PM
jackyliem's Avatar
what kind of damping setting are you guys using?
Old Nov 16, 2004 | 12:18 AM
Levi SPL S14's Avatar
You need to figure out your own settings. Let your butt dyno do the testing.
Old Nov 16, 2004 | 06:43 PM
Texas240's Avatar
stechs are pretty good.
i endedup w/ h-techs & agx's
beautiful combo, drove great in the auto-x.
i end up w/ my front agx's set on 3 and the backs(still messing w/ it.) about 4 or 5.
the non-adjustable kyb's are good, but it's better to just save your $$ for a lil longer & get the good stuffs.
Old Nov 18, 2004 | 01:07 PM
AGX are adjustable and Tokico blues are not.
Old Nov 18, 2004 | 01:24 PM
Catharsis's Avatar
agx is better than the blues, the blues are a near stock replacement
Old Nov 20, 2004 | 02:25 PM
also, blues are more compareable to KYB GR-2's
Old Nov 20, 2004 | 06:38 PM
4984 5fsdskfvjdsntr4's Avatar
Banned
The blues r alittle stiffer then the gr-2s but not as good as the agx.
As i see its an overwhelming response. AGX rule!
Old Nov 22, 2004 | 11:49 PM
How about AGX's with either Eibach or RSR springs S-techs are okay but a little too soft when you push the limit
Old Nov 23, 2004 | 02:02 AM
Doesn't KYB warn against using RSR's stiff springs because it'll prematurely wear out the springs?
Old Nov 23, 2004 | 05:07 AM
Note I didn't say RSR Race
Old Nov 25, 2004 | 02:18 PM
jackyliem's Avatar
so does it me AGX is not that hard at all? BTW what's the spring rate for all the brand?
Old Nov 25, 2004 | 08:34 PM
vbgambini's Avatar
So whats the real combo that you guys set your 95-96 240? I plan on putting 18's on it so what combo should i do? stiff and o wheel gap?
