AGX or tokico blue?
since they are about the same price. which should I get? I know tokico is a better brand but AGX is adjustable. and what spings should I use with them?
Most common and preferred combo AGXs with Tein S-Techs. AGXs are far better than the Tocikos because of adjustablilty.
Dude u got to get the s.techs with the agxs. I got mine installed yesterday and it drives and look hella good!
what kind of damping setting are you guys using?
You need to figure out your own settings. Let your butt dyno do the testing.
stechs are pretty good.
i endedup w/ h-techs & agx's beautiful combo, drove great in the auto-x. i end up w/ my front agx's set on 3 and the backs(still messing w/ it.) about 4 or 5. the non-adjustable kyb's are good, but it's better to just save your $$ for a lil longer & get the good stuffs. |
AGX are adjustable and Tokico blues are not.
agx is better than the blues, the blues are a near stock replacement
also, blues are more compareable to KYB GR-2's
The blues r alittle stiffer then the gr-2s but not as good as the agx.
As i see its an overwhelming response. AGX rule! |
How about AGX's with either Eibach or RSR springs :thumb: S-techs are okay but a little too soft when you push the limit
Doesn't KYB warn against using RSR's stiff springs because it'll prematurely wear out the springs?
Originally posted by ArticDragon Doesn't KYB warn against using RSR's stiff springs because it'll prematurely wear out the springs? |
so does it me AGX is not that hard at all? BTW what's the spring rate for all the brand?
So whats the real combo that you guys set your 95-96 240? I plan on putting 18's on it so what combo should i do? stiff and o wheel gap?
