Alignment and coilovers
Ok.. i was just wondering, when I am driving, for my car to run completely straight, my wheel has to be slightly turned to the right. Is this an alignment issue? is it my rims? is it uneven tire wear? also, i plan on purchasing some coilovers soon and was wondering if this would make the problem worse, and would getting a 4 wheel alignment, after installing the coilovers, make it run straight?
Any feedback would be greatly appreciated
Thanks
Thanks
most the time this is occured is becouse one of your front wheels has more +- toe then the other one. an alignment should cure the problem. if not just make sure the wheels are straight take the steering wheel off and put it back on there straight.
its not really a pulling feeling, its more like something i have to do to make the car run straight, when i have the wheel centered, i start going slightly to the left
but thanks for the suggestions, ill get an alignment after i get my coilovers in and see if that fixes it
