b pillar bar?
Old Mar 17, 2004 | 11:37 AM
backlife's Avatar
b pillar bar?
has any one used this it sound like it would do really good for the turning and drifting
http://www.intensepower.com/cupisibars14.html
Old Mar 20, 2004 | 03:40 AM
Re: b pillar bar?
Wow never seen those before; I'm assuming those are for people who aren't going to go with a full-on roll bar or cage.
Old Mar 20, 2004 | 08:37 AM
Justin.b's Avatar
It's hard to tell from that pic where the mounting points are - but I don't see that thing adding any noticeable rigidity. Seems more like an appearace item.
-Justin
Old Mar 20, 2004 | 01:13 PM
-Justin
well the description does say "Some drilling is required for installation."
Maybe they're trying to triangulate the B pillar to the floor rail. IMO it doesn't look like it helps that much.
Old Mar 21, 2004 | 10:30 AM
backlife's Avatar
well it looks like it mounts to the b-pillar and then to the floor which in turn should stop the b-pillar from flexing. and it looks sweet too.
i think that after you have done upper and lower strut bars front and rear, and front and rear sway bars, tie rods, camber plates, control arms and a middel stress bar i think the the b-pillar bar would finish up the rigitity issue quite nicely.
Old Mar 21, 2004 | 01:32 PM
Justin.b's Avatar
If it were a larger tube with a straight shot from the pillar to the floor I may believe it's function.... this looks like a blue coat hanger with a bend where it should be straight.
Unless there is some hidden engineering magic, I'm going to have to stick with my original verdict - appearance mod.
-Justin
Old Mar 21, 2004 | 03:02 PM
-Justin
I agree... the "triangle" formed by the B pillar, floor, and this bar should be larger. If that B pillar bar were (for example) to reach oward the center of the floor, then maybe.
Old Mar 21, 2004 | 07:51 PM
backlife's Avatar
yes but the small bar that goes up from the floor the the curved part of the other par on top prevents it all from flexing
Old Mar 21, 2004 | 08:02 PM
So you're saying that curved bar will withstand the flex of the much larger (and thicker) chassis?
Sorry, I'm not convinced. You can spend the $200 and let us know. Heh.
doriftomodachi
Apr 17, 2006 10:10 AM
rdgrcr085
Jan 21, 2006 11:06 AM
RealDS13
Feb 1, 2005 12:00 PM
SPEED n STYLEZ
Jun 16, 2004 01:05 PM
SPEED n STYLEZ
Jun 13, 2004 11:26 AM
