Breaks (your thoughts please)
Old Feb 19, 2006 | 07:48 PM
SuperHicasDevin's Avatar
Question Breaks (your thoughts please)
What would be the biggest, best brakes for the least amount of money? Would you recomend saving for thoses big break kits? Or shall I just get bigger rotors and calipers? Any suggestions?
Old Feb 19, 2006 | 07:51 PM
nsn240's Avatar
i like to take breaks after i've worked on my car for a while
if you are talking about brakes, then i'd suggest 300zx brakes. i can tell you probably havent done much research on this
Old Feb 19, 2006 | 07:54 PM
Chiefgmsr's Avatar
Don't you need to be able to stop with all the hp. But your right 300ZX 30mm calipers are good.
Old Feb 19, 2006 | 08:01 PM
...Thanks
Old Feb 19, 2006 | 08:05 PM
Most kits I've seen are front brakes, are there kits with front and rear or would I have to get front and rear kits seperately?
Old Feb 19, 2006 | 08:10 PM
Chiefgmsr's Avatar
If you're talking aftermarket brakes. I'm, not sure. i saw a guy with endless brakes and they were the size of his rims. they were front and rears. if you do the 300ZX brakes. the rears are hard to do w/o losing the e-brake. So most ppl stick with the fronts only. The rears are possible tjough. Goodluck!!!
Old Feb 19, 2006 | 08:23 PM
Thank you.
Old Feb 19, 2006 | 10:18 PM
Preston's Avatar
Read the post about brakes from stoptech. They go into why you almost never need a rear brake upgrade. Fronts are all you need to upgrade, just put some nice pads on the rear with slotted stock rotors and you'll be fine.
Old Feb 20, 2006 | 09:49 AM
thank you
Old Feb 20, 2006 | 03:53 PM
nsn240's Avatar
huh?
oh, look at zilvia too
someone on there figured out how to use sti calipers with evo rotors
Old Feb 20, 2006 | 04:22 PM
phreze's Avatar
All this may or may not be overkill. What will you be using your car for the most daily driving, autocross, a few track days here and there, drifting, drag, etc?
Most people do just fine with upgraded pads, ss brake lines, and new fluid. If your rotors are warped you can get new ones either brembo plain(non-slotted non-drilled/dimpled) or go for some project mu or other high end rotor.
If you want to blow alot of money you can get a bbk for front and rears by Greddy/GREX, Project Mu, Endless, or Stoptech. Your looking at $1000-3000 for the fronts and about the same for the rears, very overkill on such a light car.
The 300zx upgrade is common and not to hard although some peopel complain that the 300zx brakes are to on/off there is no real in between.
240sx 5spd
Sep 15, 2004 11:11 AM
Krazyballa3
Jun 9, 2004 04:13 PM
tegg_gsr
Nov 6, 2003 08:45 PM
badass240
Apr 1, 2003 10:43 PM
Sinfestboy
Dec 18, 2002 05:19 PM
