help!!!!!!! Can't depress my piston on my calipers
Old Nov 1, 2004 | 10:37 AM
bcvjj21's Avatar
Exclamation help!!!!!!! Can't depress my piston on my calipers
Hi guys i need help fast my pistons will not for the life of me depress i think i've tried every thing. I even bought that piston turning tool. Are they seized? they move very slowly but it's way too much pressure needed turn them. Should i detach the brake lines? Help!! Damn crappy stock calipers!!!
Old Nov 1, 2004 | 11:10 AM
Did you open up the master cylinder?
Old Nov 1, 2004 | 11:57 AM
bcvjj21's Avatar
nah should i try that i thought u are suppose to just push and turn the pistons
Old Nov 1, 2004 | 01:59 PM
If it's to hard to push the piston in, try opening the brake MC and see how hard it is. If it's still hard, you might have a seized piston
Old Nov 2, 2004 | 02:18 AM
bo2o's Avatar
are you doin front or rear? and does it have a cross on the top of the piston head? if so ur suppose to screw it in
Old Nov 2, 2004 | 04:19 AM
driftjunke's Avatar
If it's the rear make sure your e-brake is off, happens all of the time. Also the rears you have to turn to compress.
E
Old Nov 2, 2004 | 03:06 PM
bcvjj21's Avatar
Yea im doing the rear the i bought the turning tool. I opened the master cylinder still no luck i took off the bleeder screws still no luck im almost sure it's siezed up. Does anybody know who sells remanufactured ones for cheap? O and by the way both of them are seized up i think.
Old Nov 2, 2004 | 06:11 PM
Check a local junkyard, wanted ads.
Old Nov 2, 2004 | 07:37 PM
chiroke's Avatar
hey open the bleed valve and push it in i had same problem with my celica but that went in reall ez when i opened it make sure to take air out when closing hope it helps worked for me =\
Old Nov 3, 2004 | 12:11 PM
Jigoku Z's Avatar
like many have said already... you don't press it in.. you screw it in....
Old Nov 6, 2004 | 05:16 PM
smokey240sx's Avatar
yup, when i first did mine i thought you pushed it. I use needle nose plyers to screw the piston down. Remember "Righty tighty, Lefty loosey."
Old Nov 7, 2004 | 11:55 PM
Aniki_Andy's Avatar
impact wrench+extention+turning tool~! =D if that doesnt get it nothing will be careful with this tho
BigVinnie
Feb 17, 2008 07:52 AM
BmoresZenkiS14
Aug 13, 2006 01:04 PM
JDM INSPIRED
Jan 11, 2006 06:01 PM
JDMxDrift
Aug 6, 2005 10:33 PM
badman70_1
16
Mar 1, 2004 08:02 AM
