lower control arm. "ball joint"????
Old Aug 13, 2008 | 07:57 PM
JDs240's Avatar
Its probably really simple, but I need to know how to grease the little rubber boot without a grease fitting
Old Aug 13, 2008 | 09:46 PM
it is simple you can't, well you can but it would be pointless because you probably damage the boot in the process.
Old Aug 14, 2008 | 01:43 PM
JDs240's Avatar
well the thing is i got a used one because my lower control arm was bent and the one i just bought has the boot busted
Old Aug 14, 2008 | 07:02 PM
if the boot is busted then you have a bigger problem than a dry ball joint. sand, water, debris and so froth can enter and cause more damage.
Old Aug 14, 2008 | 07:34 PM
JDs240's Avatar
well its not that's its dry, its just that I was wondering how to replace the boot on the factory control arm
Old Aug 14, 2008 | 10:20 PM
Rotary_tech's Avatar
doesn't energy suspension make some sort of polyurethane ball joint boot for 240's???
Old Aug 19, 2008 | 07:46 PM
BlackZenki82's Avatar
i got the same problem on mine.... and was just going to replace it all together....
epp_b
May 22, 2007 01:36 PM
Hedonist
Dec 2, 2006 06:37 AM
Carparthookup
Dec 13, 2005 09:47 AM
smokie700
Jul 13, 2004 02:31 PM
Dres240
Mar 3, 2004 10:32 AM
