Parking brake light
Old Jul 30, 2005 | 03:51 PM
jfrederi01's Avatar
Parking brake light
My parking brake light will not turn off. It started happening about two weeks ago. I can release the brake but for some reason the light will not go out. Has anyone else had this problem? I would like some insight before I tear apart my dash. Thanks.
Old Jul 30, 2005 | 04:27 PM
silviadriver's Avatar
check brake fluid
Old Jul 30, 2005 | 05:01 PM
2fast4y0u's Avatar
i am having this same problem and i did all the required things...brake fluid, brake pads, light sensor, power, ground all that mine in still on...its a pain in the ***!
Old Jul 30, 2005 | 09:03 PM
jfrederi01's Avatar
yeah I checked all those too, but nothing came up. WTF
Old Jul 31, 2005 | 06:55 AM
shotty53's Avatar
this happened to my sisters sentra. when u push in the brakes, there is a pin *most likely stuck) that pushes a button that allows the brake lights to go on...
just check to see that its not stuck
Old Jul 31, 2005 | 01:56 PM
Levi SPL S14's Avatar
gah!!! i forgot about that sensor in the back fo the pedal check that
Old Aug 1, 2005 | 07:51 AM
2fast4y0u's Avatar
still is functional... i hate that stupid light!
Old Aug 1, 2005 | 08:36 AM
WTF I am having that same problem. But I think its coming from my Hand Brake. I disconnected the harness but the light was still on.....
I <3 240's
Old Aug 1, 2005 | 09:05 AM
2fast4y0u's Avatar
thats the problem we are having...from the e-brake/ hand brake/ wee stick
Old Aug 1, 2005 | 12:38 PM
you guys check the little metal contact under the center console, right? Or not?
Old Aug 1, 2005 | 02:23 PM
2fast4y0u's Avatar
i did...
Old Aug 1, 2005 | 02:58 PM
i know this sounds simple, but check the button on the end of the handbrake it could be stuck or jammed
Old Aug 1, 2005 | 06:38 PM
2fast4y0u's Avatar
thats what mad eit start in the first place i think....i was trying to install my drift button and it stayed on after that
it never came on when i just pressed in the button before though
im going to go play with it right now to see if i can get it to work.
Bumnah
Jan 4, 2008 07:40 PM
Suhster85
West Coast/Hawaii
Feb 27, 2004 12:26 PM
SoCalTURBO
Jan 21, 2004 01:07 PM
evilsil
Dec 18, 2003 05:34 PM
jtsarnak
Jan 7, 2003 07:19 PM
