Rear End?
Old Sep 16, 2005 | 10:24 AM
bullet23's Avatar
Rear End?
I'm having trouble with my back end. When ever i go over bumps, small multiple bumps, my rear tires bounce over them and the whole car vibrates. I was wondering if coilovers would solve this, i've heard they are stiff so, i didn't know. My shocks or struts I forgot the diff. are shot and need to be replaced. thanks for the input.
Old Sep 16, 2005 | 02:00 PM
Levi SPL S14's Avatar
you diff is done?
wow wtf did you do?
your not ready for coilovers.
Old Sep 19, 2005 | 08:35 AM
bullet23's Avatar
no my differential is fine as far as i know, i meant that i forget the difference between shocks and struts. i just shortened difference for some reason.
Old Sep 19, 2005 | 03:25 PM
ConceptS14's Avatar
sounds like your rear shock(s) are bad.
Old Sep 20, 2005 | 05:45 PM
shocks are probably done, and/or maybe your subframe spacers are dried up.
Advice: if you don't know the difference between shocks and struts, stay away from coilovers until you have more car knowledge bro =)
Old Sep 22, 2005 | 06:14 PM
rocky2843's Avatar
im having this same problem but it feels like when i go over bumps that my back end kinda feels like it fishtails back and forth...doesnt feel like my tires are but the body itself, liek swaying...i was thinking it was the spacers but i dont know. what do u guys think?
Old Sep 22, 2005 | 07:51 PM
Kinematics's Avatar
I had that problem with my 90. The dampers were definitely blown, but I figured the side to side sorta sway was from the bushings in the suspension being worn out.
I replaced the rear dampers with some used GR-2s and the feel of the car firmed right up.
To see if your dampers are blown, go push on the fender of the car above the wheel well, with the intentions of compressing the shock and making it bounce. You might have to 'pump' the car a few times to build up the necessary momentum. If the car rebounds more than once, your dampers are likely blown.
Old Sep 22, 2005 | 07:53 PM
Kinematics's Avatar
Doublepost.
Old Sep 22, 2005 | 09:44 PM
rocky2843's Avatar
cool im gonna wake up and try it...
Old Sep 26, 2005 | 03:44 PM
rocky2843's Avatar
ok it only rebounded one time...what else could this be? tie end rods, spacers, tension rods??
Old Oct 2, 2005 | 06:52 PM
rocky2843's Avatar
anyone???
Juiced
Apr 2, 2008 11:39 PM
rrh22
Sep 11, 2003 10:03 AM
Roaland t.H.T.G
Jul 31, 2003 02:17 PM
dkdeleon
Mar 28, 2003 03:44 AM
180SXcoolguy
Mar 6, 2003 12:53 PM
