Rear Rotors/Brakes/Caliper NOISES!!! HELP!!!
Old Apr 23, 2004 | 09:23 PM
DRFT240's Avatar
the problem is on a Z32 300zx. whenever you brake, the rear caliper and rotors seem to be scraping on eachother. it's a metal on metal noise. i know for sure it's not the brake pads because it's not a squeeking noise. anyone have any ideas of what it could be? and any suggestions on how to fix it? HELP
Old Apr 23, 2004 | 10:57 PM
Have you checked the pistons to see if they are locked? That could be causing your problem
Old Apr 23, 2004 | 11:49 PM
LTSCUDRFT's Avatar
it could be your pads they may be metal to metal (your pad could be worn unevenly, from a siezed slider) and not all pads have squeekers in them, or you could be missing a brake pad alltogether.
Old Apr 24, 2004 | 12:17 AM
DRFT240's Avatar
yup.... we found out that it was an uneven brake pad.... the outer rim of the rotor was graded down and was rough. i checked the pad and the back end of it was bad. thanks for the posts.
SmokedZenki
Jan 18, 2010 08:36 PM
Timtiminy
Sep 22, 2006 01:25 AM
rancidnsx
Mar 8, 2005 11:54 PM
PissonH
Aug 28, 2004 11:45 PM
santana
Oct 15, 2003 05:24 PM
