Rear subframe spacers...
Old Jan 18, 2006 | 02:09 PM
vbgambini's Avatar
Im about to order some subframe spacers so the clunk noise will stop in the rear. Will I need anything else to install? or do i just use those spacers and thats it? Do I need to replace anything else to make them fit like the old bushings? thank you
Old Jan 18, 2006 | 06:13 PM
You just need the spacers. They do not replace the old bushings, its more like a sandwhich. The spacers usually consist of eight pieces, four for the top and four for the bottom. The ones for the top are usually slotted, allowing you to slide them into place without entirely dropping the entire subframe. The installation process is very easy.
Old Jan 18, 2006 | 06:17 PM
what brand are you looking to get?
Old Jan 18, 2006 | 06:18 PM
vbgambini's Avatar
i just got them off ebay for 64$ shipped. they were forged alloy i think. jdm slp subframe spacers. im tryin 2 see how much it would be to install cuz i dont have the tools. just 2 jack stands and a jack
Old Jan 18, 2006 | 06:19 PM
vbgambini's Avatar
even if the stock bushings are messed up or broken i can just get them installed? Raine i wanted to know how you did that headlight mod with the high beams. i wanna be able to turn them on separately.
Old Jan 18, 2006 | 06:23 PM
should be fine with pretty wore bushings, thats kind of the point of the spacers, all you really need is a jack, jackstands, and a set of sockets
Old Jan 18, 2006 | 06:25 PM
vbgambini's Avatar
are the old bolts welded on the s14? will they be easy to take off and everything like that?
Old Jan 18, 2006 | 06:29 PM
They are not welded, at least they shouln't be, if they are sell your car because the previous owner was crazy. Seriously though, they might require a little force but should come off with just basic tools.
Old Jan 18, 2006 | 06:32 PM
vbgambini's Avatar
hahaha aiight ill check that. i love my car tho. are there any pix to where i gotta work or is it pretty much self explanitory when i get under the car?
Old Jan 18, 2006 | 06:39 PM
searched the net real quick and found this from NICO, check it out
Old Jan 18, 2006 | 06:43 PM
vbgambini's Avatar
thanks man. you da man.
vbgambini's Avatar
u have any idea how raine did that with his high beams where you can turn them on separately? lol
Old Jan 18, 2006 | 06:44 PM
no problem
2fourDS14
Jul 2, 2008 02:26 AM
JDMxDrift
Jul 16, 2005 03:50 PM
yektik99
Feb 3, 2005 02:25 PM
aj240sx
Sep 16, 2003 09:19 AM
kboonhower
Jun 15, 2003 08:24 PM
