right front strut LOUD!!!!
Old Dec 10, 2004 | 12:42 PM
michael's Avatar
i just repl my strut mounts and no when i turn i can hear noise like you would hear from old door that needs wd-40. nothing is loose. i did loose the little plastic cover that goes arond the bottom of spring, is this the cause? i had my bud turn the wheel and cant pin point.
Old Dec 10, 2004 | 01:01 PM
240sxNLR's Avatar
it could be dirt or derbris in teh spring mount...I have had this poblem with rubber contacts on metal before..may need to either spray some silicone lube to hopefully work it out or take it back apart and clean the seats before reinstall
Old Dec 11, 2004 | 01:29 AM
bimmian's Avatar
When do you get the noise? Is it when you're going slow, ie out of your driveway or just slow turns? Is it a groaning and/or popping noise?
If its that then it is most likely your strut mount bearing.
www.pdm-racing.com has oem replacements.
Old Dec 11, 2004 | 03:21 PM
2fast4y0u's Avatar
i had that same problem. put some anti-sieze on the spring mount where it touches the metal part. problems solved. you might have to put some on there everytime you wash it really good, but other than that, no probs
Old Dec 13, 2004 | 12:34 PM
michael's Avatar
strut loud
it happens when i turn the wheels, my trans axle is worn and will need to repl, this may be the problem. and i just repl the mounts. thats when i herd the problem. no mater if foward or back. ill spray with some lube and keep you guys posted.
Bryan
Feb 14, 2006 05:26 PM
Preston
Dec 30, 2005 11:51 AM
ricks89240
Sep 25, 2003 07:35 AM
tristan
Sep 1, 2003 03:22 PM
95_240SXSE
Aug 31, 2003 12:06 AM
