Rotors warped, or just need adjustment?
Old Aug 10, 2005 | 08:59 AM
M374llic4's Avatar
How do you know if your rotors are warped or just need to be rotated. My car, when the brakes warmed up, would bounce and **** like crazy when braking.
Did it so hard my drink spilled from my ashtray and it broke my tie rod end. The wheel now, when driving will sometimes randomly start to bounce as if i was hitting the brake.
When its really hot outside and such, my brakes i guess, are always on? It will rub and i press the pedal and there is no play in it. Its just stiff and instantly engages teh brakes when pressed even slightly.
And i smell the brakes as i drive from rubbing.
I think the rotor is so warped, that when it heats up, its always touching the brake pad??
What else could be the cause??
Old Aug 10, 2005 | 10:27 AM
shotty53's Avatar
one way to tell if its warped is when u resurface ur rotor... just buy a new one.. wont cost more than $25
Old Aug 11, 2005 | 07:59 PM
M374llic4's Avatar
I had the rotors cnc'd, got new tein tie rods and ends, and a few other things, now it rides great ^_^
Old Aug 11, 2005 | 08:04 PM
pooptown's Avatar
I'd say rotors, I'd jsut get new rotors and pads or calipers to if ya want, wouldn't hurt, but I'm not sure if alot of constant heat like that can warp the calipers or anything, but yeah like shotty53 said new rotors are cheap
Old Aug 11, 2005 | 08:23 PM
M374llic4's Avatar
I know : P I just said, i had them turned and now everything is fine : P
Old Aug 11, 2005 | 08:52 PM
pooptown's Avatar
ah my bad, I was thinkin someone else started this post for some weird weird reason, sorry about that
lrb_2000
Jul 17, 2005 05:04 PM
jdmsoarer
Nov 23, 2004 05:24 PM
TheStartingLine
Mar 22, 2004 09:37 PM
cheap240
Oct 15, 2003 07:25 PM
stannyboy
Sep 30, 2003 07:55 AM
