RUCA Squeaks???
Old Jun 3, 2005 | 12:33 AM
bosozoku s14's Avatar
RUCA Squeaks???
i already searched the forum, looks like people only suggest grease to help
solve the problem but it didnt work for me, so i thought i might ask to see if
it is something else wrong.
here's the story:
i installed tanabe RUCA for my S14 couple days ago, I started hearing
crazy squeaking noise from the rear passenger side i believe. I already
grease them today since i forgot the first time, seems like it didnt help at all.
the squeaking noise wasnt too loud, but i can hear it every little bump no
matter on highway or locals. im wondering if i did something wrong and
what can i do to fix it since it really annoys me.
btw, i have tein ss and spl subframe spacers on my car...
please help me out.
thanks in advance.
Old Jun 3, 2005 | 02:00 AM
Levi SPL S14's Avatar
check out your coilovers it may be the springs
to much preload causes that to happen at times
Old Jun 3, 2005 | 02:54 AM
KeN VeRsUs RyU's Avatar
that happened to me too.. i found out it was my lower control arm bolt (threaded side) was actually rubbing up against the shock.
Old Jun 3, 2005 | 08:36 AM
LandHo_S13: that only happens it i slam the car right, my car is not that low, plus i've had my coilovers for almost 2 months, never heard of anything before the RUCA.
KeN VeRsUs RyU: do you have RUCA? how did u end up fixing the problem?
Old Jun 3, 2005 | 01:42 PM
Yeah i have RUCA. It only happened when i slammed it (couldn't fit my finger in the fender) and eyed the camber myself. Then i realized i couldn't take the shock off the hub because the lower arm bolt was in the way so i took a saw and just sawed off the threaded side right up to the nut. I didn't take anything off to do that.. i just did it right on the car.
I'm not sure if that's what you're experiencing but look at your shock and see if anything is rubbing.
Old Jun 3, 2005 | 02:41 PM
No the car does not have to be slammed. Just take a good look at yoru suspension make sure nothing is hitting or rubbing of the sorts.
Old Jun 5, 2005 | 03:16 PM
eyeball camber = don't fool yourself.
if nothing is rubbing but you're getting those noises, your car might be too low and your bushings might be too old.
Rawr.
jspaeth
Jun 9, 2006 05:48 PM
2fourDS14
Aug 31, 2005 08:34 PM
bassman31386
Feb 15, 2005 08:39 AM
silviadriver
Nov 21, 2004 07:35 PM
kable
Apr 2, 2004 11:37 AM
