super hicas?
Old Oct 25, 2003 | 10:14 AM
matt180sx's Avatar
super hicas?
i just purchased a 91 240 fastback, its clean for the year and seems mechanically solid. But it has super HICAS on it with abs and lsd. I found out the hicas system is a form of four wheel steering. Im just wondering if it will interfere with me lowering the car or adding other suspension upgrades. I want to start drifting in the car, and i wasnt sure if i could with the four wheel steering.
Old Oct 25, 2003 | 12:50 PM
RS13's Avatar
You can it just gonna behave a little different than a non-HICAS car would. there are also kits to eliminate them or you can save about 40 Lbs and buy a new rear subframe
It'll be fine
Old Oct 25, 2003 | 07:42 PM
matt180sx's Avatar
if i get a new rear subframe will i need to do anything with wiring, i heard it is electronically controlled. also is it just the suspension parts that need to be swapped or a whole new part to the frame, and i assume these are parts i can find in a wrecking yard. or should i try to get them from the far east?
Old Oct 25, 2003 | 09:23 PM
Cant ya just disconnect the HICAS and eliminate it like that..but u still got the extra weight from the HICAS stuff. HICAS models are rare man, be happy u got one
Old Oct 26, 2003 | 12:47 AM
matt180sx's Avatar
really? how rare are they? maybe thats why i really havent heard much about them. are they prone to any problems with the rear steering?
Old Oct 26, 2003 | 09:15 AM
Well i dont know if theyre are any differnt problems then a regular 240 because not many people have em at all. HICAS models are very rare...ive only knows 1 other person that has one.
Old Oct 26, 2003 | 01:34 PM
drnovascotia's Avatar
yeah, my 93 is a HICAS as well. they are damn rare, I haven't seen another 240 HICAS edition. (althought mine doesn't have the ABS, heh)
Lowering the car is no different, nor is any other suspension. I've put KYB AGX's & Eibachs, changed tie rod ends, strut bar and i'm in the process of saving for whiteline TC rods.
If you're seroius into drifting then I was told to disable to hicas. If not, then it's definately a plus to have, if you drive a 240 without the LSD and then one with you can tell the difference.
Dr.
Old Oct 26, 2003 | 06:45 PM
matt180sx's Avatar
well i want to start getting into drifting, thats why i bought the 240, but if the hicas is rare i dont know if i want to take it out, i might find another one for a drifter and make this one a show car. also wondering if the hicas light on the dash is supposed to be on all the time?
Old Oct 26, 2003 | 08:55 PM
Hmm i would just stick with the HICAS model, only reason i would get a HICAS model is kus it comes with the VLSD. Its a great drift car stock...just minus the HICAS lol. The car would still be rare..unless ur ganna sell the car later on then i would take out the HICAS
Old Oct 27, 2003 | 09:32 AM
rudeboy's Avatar
remember people.
some rear shocks wont work because of the adjustablilty.
removing the hicas is as simple as removin the rear rack, installin an eliminator. and switching power steering pumps.
Old Oct 29, 2003 | 12:51 PM
matt180sx's Avatar
where can i find detailed instructions on how to do this my self?
slipperypanda
Jun 25, 2007 05:44 PM
bl200sx
Sep 24, 2003 04:50 PM
kingcarm
Jun 12, 2003 03:38 PM
Griffin
Mar 6, 2003 11:11 AM
spitz7985
Jul 29, 2002 02:24 PM
