suspension
suspension
hey guys im only 16 and on a tight budget i juss got my car all stock... i want to get suspension then a possibly r200 lsd swap or a vlsd swap.... but as for suspension shoudl i pick up on koni yellows/prokit for 425..... or agx/prokit.... for 300... both used... how much life would they have left? itz goign to be a daily driver and a weekend drift toy... do u guys think some ground controls and maybe yellows or agxs could handle drifting?? help me out!!! pleasE!
Adjusting the height with your mood is a bad idea. Unless you have access to corner scales or can afford to pay someone who does to setup your coilovers then leave the adjustable spring perches alone.
-Justin
-Justin
It is easy. Just turn the perches.
The thing that most people don't realize is that without corner weighting the car you will likely end up with a car that handles worse than if you had just bought a desent set of dampoers and lowering springs.
The potential of coilovers is greater, but unless they're properly set up you can end up with freaky handling.
-Justin
-Justin
-Justin
-Justin
Hi guys just bought my 98 240SX SE 6 month ago and I want to drop my car about 1.2-1.5" mostly for city driving, but i do take my corners at high speeds. The suspension that my car has is awesome, but I want it to be a bit better and the car be a little lower. I dont want the ride quality to suffer too much... and my tirewear to increase dramatically. I want to spend about $1000-$1500. Can you please recommend a good setup ?
ALso, my steering wheel been feeling kind of lose... is that because i ***ed up some buchin* in the suspension ?
Eibach ProKits and KYB AGX shocks will drop your car about 1.5" for $650. If you've decided to spend the budget of $1000 you could go with a Tein coilover setup that will allow for adjustability, or you could put the extra towarsds turbo parts / brakes / other suspension stuff.
-Justin
-Justin
Sizzzoooo
Mar 11, 2002 01:56 PM
