sway bar wtf?
Old Aug 8, 2006 | 09:23 PM
Akhu's Avatar
sway bar wtf?
So my car has this problem, it squeeks sometimes when i go over speed bumps, but it always makes a clunking sound whenever i go over any speed bumps and also makes a clunking sound when i apply the brakes. tonight i went to isolate the problem, i assumed it was the control arms, so i had purchased two new front control arms, one for each side. i took the control arm off, and the bushing was good, the ball joint didnt appear messed up, no vertical play at all. so i took off the sway bar and drove my car over some speed bumps and sure enough, no clunking sound and i noticed right away there was no clunking sound when i applied the brakes. hmm indeed. i'm going to leave the sway bar off until i inspect the problem further. i'm thinking that:
a) the bushings are pretty bad
b) it was in a front end accident on the side it clunks from, so the tension bar may be bent and they never replaced it, which would cause it to hit the sway bar...
c) the tension bar bushings are bad, causing it to hit the sway bar, creating the clunking sound.
futureteg
May 26, 2005 11:10 PM
jackyliem
Dec 9, 2004 01:04 PM
s13hybrid
Jul 28, 2004 04:44 PM
Gr3En
Jun 29, 2004 09:42 PM
P_Daudy
Feb 26, 2004 06:38 AM
