brakie noise
Old Aug 10, 2006 | 07:14 PM
thabeast's Avatar
brakie noise
wats uppp guyssss i just changed all my brakes and rotorss not even a month ago.....iveee givin them there share off abuse buttt mostly normal drivingggg all of a sudden i hear a thumping and thudding soundddd comming from the breaksss under normal usageeee when changiing the pads i did not use break quiet or anything like that so i im not sure if that is it . i have no idea what thsi could be... i am aware that my e brake is basically none existant ..i mean it is really bad i could pull on it and almost nothing happends..just a mild mild slowwing of the car......anyone have any ideas before i go into this blind?????????
Old Aug 10, 2006 | 07:23 PM
mabey if you could type better we could understand what your trying to say.
Old Aug 10, 2006 | 08:24 PM
thabeast's Avatar
okkkkk ...ummm my breaks are newww.....installed properly but my e breakk is bad...under normal breaking i hear a thump and thud noise esp in reversee although the breaks perform well .....what could this be
Old Aug 11, 2006 | 01:01 AM
re037's Avatar
bearings?
Old Aug 11, 2006 | 07:05 AM
thabeast's Avatar
UPDATEEE:: the thump is more like a harddddd rbbing noiseee and it only happendswhen im in reverseee not in drive....... any ideas?
Old Aug 11, 2006 | 07:53 AM
and it didnt do this before? all s13s make funky noises in reverse....try backing up at a decent speed and then bring it out of reverse while still rolling backwards and see if it still makes the noise...if so then it may be brakes, if not, thennnnnnn jussssssssstttttttttt getttt usedddddd to itt !!!!!!!!111111111111
Old Aug 11, 2006 | 08:53 AM
thabeast's Avatar
IM TALKIN LOUDDD THOO AND ITS ONLY UNDER BREAKING IF U PUMP THE BREAK PEDAL THE SOUND IS LIKE..........DUNNNNNNN DUNNNNNN DUNNNNNNNNNNNNNNN
dkdeleon
Apr 21, 2003 04:08 PM
s0ldats
Dec 22, 2002 11:21 AM
drpepper180
Nov 22, 2002 09:55 AM
SilvaPwr
Oct 17, 2002 02:02 PM
drifties151
Oct 8, 2002 12:30 PM
