tein 2-tech lowering springs
Old Sep 10, 2006 | 04:38 PM
240's"r"us's Avatar
Question tein s-tech lowering springs
ok im getting some of these for christmas http://www.optionimports.com/teslospfor952.html
im wondering if this price is for front and rear or just a pair
the reason im getting these instead of coilovers is becouse im 14 and dont have a job so there you go
also is there anything elese i should use with these
help would be highly appreciated
Old Sep 10, 2006 | 04:55 PM
240's"r"us's Avatar
also have you all heard anything bad about them?
hows the ride?
do know of any that are better?
and could i still put 18's under there?
Old Sep 10, 2006 | 05:50 PM
you can get those springs alot cheaper on ebay. do you have aftermarket shocks? 18s will be no problem as long they are correct width/offset and wont rub
Old Sep 10, 2006 | 05:56 PM
240's"r"us's Avatar
no i have stock shocks as of now should i get aftermarket ones?
and rim sizes will be 18x9+20 so i know theyll be good
Old Sep 10, 2006 | 06:10 PM
Black240Coupe's Avatar
i have the Tein S Tech springs on my car with the KYB AGX shocks....best 500 i spent on suspension....but they def arent coilovers
Old Sep 10, 2006 | 06:11 PM
240's"r"us's Avatar
do you think i should get new shocks as well?
to the above poster how does it ride
Old Sep 10, 2006 | 06:50 PM
nixad's Avatar
I can say the exact same thing.
YES! you should get new shocks with the springs, from what i've heard the Tein S techs are a bit soft. odds are if you jsut change the springs you wont feel much of a differnce.
I suggest getting a bigger sway bar for the rear and soem strut bars aswell.
Old Sep 10, 2006 | 07:05 PM
240's"r"us's Avatar
ok i have found them in a package for the s13 but not s14 any help people?
Old Sep 10, 2006 | 07:40 PM
nixad's Avatar
ebay.com
froogle.com
summitracing.com
Should have it.
Old Sep 10, 2006 | 07:44 PM
240's"r"us's Avatar
would you recomend getting ajustable damping or not?
Old Sep 10, 2006 | 08:04 PM
kyb agx ftw, dampening would be nice, or save a little more and buy coilovers, just to let you know the drop isnt much on the stechs and ive heard they ride pretty soft..get some rsr's or eibach or something if you insist on springs..
Old Sep 10, 2006 | 08:34 PM
if you get agx keep them all the way stiff, they last longer
Old Sep 11, 2006 | 01:52 AM
nixad's Avatar
You joking?
I have mine on real stiff and lets just say the passangers usally don't care for it too much
Old Sep 11, 2006 | 07:23 AM
dead serious. there is more travel with it on a softer setting so more heat and friction
Old Sep 11, 2006 | 07:45 AM
nixad's Avatar
Ya, I was told that if you do a drop greater then 1.2" there not ment for handling that either. That all makes sence though.
Just curious what does everyone have there setup at? I use 2 in the front then 8 on the rears.
