TEIN SS Install question HELP
Old Mar 11, 2006 | 04:23 PM
jspaeth's Avatar
I installed a set of Super Streets today, and everything went fine.........
However , I made one assumption.....the rear struts are unmarked, so clearly they both work on both sides.......
However, at the BOTTOM of the strut assembly, where the 17mm bolt goes through, the strut is not symmetric
IT IS WIDER ON ONE SIDE THAN THE OTHER........
Does anyone know which side should face IN/OUT.........?
For now, I have the side with the "spacer" facing outward toward the wheel......this makes the negative camber a little higher I believe.......
IS there a CORRECT WAY to choose how the strut should go on?
The directions sure as hell didn't say so!
Help would be great here
Old Mar 11, 2006 | 07:13 PM
Levi SPL S14's Avatar
YOU DONT MAKE SENSE!!!
Your stock suspension where the 17mm bolt goes in is wide to small. Wide should face the knuckle.
That does not give you any negative camber. Only the accentric bolts on the camber arm do that.
Old Mar 11, 2006 | 08:48 PM
jspaeth's Avatar
What I was trying to explain was that depending upon which way it goes on, the angle that the whole strut makes (in terms of perpendicularity with respect to the ground) can change
If I put the part with the "spacer" closer to the wheel (facing outside), then the strut tower is more angled, as compared to if is were rotated 180
So, is there a right way.........it seems to fit on both ways without a problem, but i want to make sure it is correct.......
Old Mar 12, 2006 | 09:13 AM
jspaeth's Avatar
here is a pic of what i am talking about:
I KNOW THIS ISN'T THE SAME SET OF COILOVERS, but the bottom end of mine look identical (for the rears)
on the 2nd from the left (rear STRUT) in the picture, at the bottom of the strut, notice there is some "extra metal" or something on the right side of the strut.......
which way should this face............SOMEBODYYYY! HELPPPP!
Old Mar 12, 2006 | 04:24 PM
there is extra metal but if you look at it one side has a larger hole than the other.
the larger side goes towards the knuckle.
Old Mar 12, 2006 | 04:52 PM
jspaeth's Avatar
ok i will have to double check how i have it on there.....i could have sworn both were the same size....i think this will make a difference, right now my rears are pretty toe in and negatively cambered.....
i'm slapping on some 17x9 work emotions next weekend +17 rear and either +25 or +17 front
pictures to come, the **** looks good slammed
Old Mar 12, 2006 | 09:16 PM
the position of the rear shock (it's not a strut) doesn't change camber or toe. The 'angle' isn't an issue as it is up front.
BTW Go get an alignment, if you go lower than about 1.5" or so you won't get the wheel straight without RUCAS/Toe Rods.
And again since it seems you're not getting the idea - the thicker side goes to the knuckle. If you put it the other way the shock end sorta is too close to the knuckle.
Kay.
Old Mar 13, 2006 | 05:09 AM
jspaeth's Avatar
Okay, so for example, in the above picture, the 2nd shock from the left, as it is oriented in the picture, would go on the right side...........?
If so, that is how i have it now...........thanks for the help all.
P.S. My friends suggest I wait to get it aligned until after I slap on the new wheels..........should be in about a week, and I won't be driving much till then.
Old Mar 13, 2006 | 10:28 AM
DriftOrDieTryin's Avatar
tein gives out mad amounts of stickers....
Old Mar 13, 2006 | 03:59 PM
jspaeth's Avatar
THANKS Everyone for your help.....
I finally heard back from TEIN, and for the Super Streets on the rear, the wider part faces outside, toward the wheel
Old Mar 13, 2006 | 07:14 PM
I think 3 of us told you that.
Old Mar 13, 2006 | 08:23 PM
jspaeth's Avatar
Yeah i heard mixed things from other sources, so whatever, it's finalized
2plus4plus0EQ6
Oct 24, 2006 08:54 PM
Flip_240Sex
Mar 1, 2006 05:55 AM
azndummie
18
Sep 30, 2005 04:37 AM
S14Dude
Apr 23, 2005 12:41 PM
ACE_20
15
Mar 4, 2005 09:38 AM
