tein tie rods, is it worth it
is it worth it to invest 150$ on tein tie rods(2 outer), will it really make a difference of should i just get regular ones for 40$ each
Re: tein tie rods, is it worth it
Originally posted by PissonH is it worth it to invest 150$ on tein tie rods(2 outer), will it really make a difference of should i just get regular ones for 40$ each ...wait, what do you mean by "two outer"? Do you mean tension rods? |
nah, well you have the inner tie rods and the other tie rods from your rack and pinion shaft,
but are they really worth the price those tein rods thanks |
tein are only compatible with the tein tie rod ends, they I REPEAT NOT compatible if you mix match them with stock pieces.
SLP parts are better
Tien uses S14 threads on their tie rods so yes it is possible to use stock ends with them. Just make sure they're for an S14 (even if you have an S13). Anyway about the tie rods I got them on my car and I believe they are worth the money over stock. The stiffer bushings and spacers WILL make a noticable difference in steering feel.
well i have an s14 and although i didn't ry the instuctions and all the research i did said that tein's were not compatible with stock ends
that i know, my question is are they worth it over stock ones for the price you pay for them
yes but spend the money for the SLP parts for now there will be better products coming out soon for less money
slp means what
Originally posted by PissonH slp means what |
its the brand
not sure about SPL heard good things about them but tein is a proven brand. I feel any aftermarket part that is good quality will be better than stock.
Originally posted by smokie700 not sure about SPL heard good things about them but tein is a proven brand. I feel any aftermarket part that is good quality will be better than stock. |
Originally posted by PissonH is it worth it to invest 150$ on tein tie rods(2 outer), will it really make a difference of should i just get regular ones for 40$ each |
