tein tie rods, is it worth it
Old Jul 6, 2004 | 05:37 PM
PissonH's Avatar
is it worth it to invest 150$ on tein tie rods(2 outer), will it really make a difference of should i just get regular ones for 40$ each
Old Jul 9, 2004 | 10:09 AM
Re: tein tie rods, is it worth it
stockers might bend under hard driving.
...wait, what do you mean by "two outer"? Do you mean tension rods?
Old Jul 9, 2004 | 12:41 PM
PissonH's Avatar
nah, well you have the inner tie rods and the other tie rods from your rack and pinion shaft,
but are they really worth the price those tein rods
thanks
Old Jul 9, 2004 | 02:56 PM
smokie700's Avatar
tein are only compatible with the tein tie rod ends, they I REPEAT NOT compatible if you mix match them with stock pieces.
Old Jul 9, 2004 | 05:09 PM
Catharsis's Avatar
SLP parts are better
Old Jul 9, 2004 | 07:11 PM
I'm with Stupid's Avatar
Tien uses S14 threads on their tie rods so yes it is possible to use stock ends with them. Just make sure they're for an S14 (even if you have an S13). Anyway about the tie rods I got them on my car and I believe they are worth the money over stock. The stiffer bushings and spacers WILL make a noticable difference in steering feel.
Old Jul 9, 2004 | 08:30 PM
smokie700's Avatar
well i have an s14 and although i didn't ry the instuctions and all the research i did said that tein's were not compatible with stock ends
Old Jul 9, 2004 | 08:49 PM
PissonH's Avatar
that i know, my question is are they worth it over stock ones for the price you pay for them
Old Jul 9, 2004 | 08:54 PM
Catharsis's Avatar
yes but spend the money for the SLP parts for now there will be better products coming out soon for less money
Old Jul 9, 2004 | 09:00 PM
PissonH's Avatar
slp means what
Old Jul 9, 2004 | 11:16 PM
slp means what
I think he meant SPL: http://www.splparts.com/
Old Jul 10, 2004 | 11:51 PM
Catharsis's Avatar
its the brand
Old Jul 11, 2004 | 01:51 AM
smokie700's Avatar
not sure about SPL heard good things about them but tein is a proven brand. I feel any aftermarket part that is good quality will be better than stock.
Old Jul 11, 2004 | 11:46 AM
I heard that SPL tension rods can hang with Tein in terms of strength, but I haven't heard anything about the tie rods
Old Jul 12, 2004 | 11:06 AM
JeromeS13's Avatar
Teins are great. And, btw, when you get the Tein tie rods, you get both sides, complete. You get the two tie rods AND both outer tie rod ends...
