Wheel Spacers
Old Jun 4, 2005 | 12:22 PM
JDMxDrift's Avatar
Red face Wheel Spacers
Which are safer to run, the adapter style or spacer/ext. wheel stud style?
Old Jun 4, 2005 | 02:21 PM
Levi SPL S14's Avatar
well both have there pros and cons.
If you use a bolt on spacer make sure its a reputable company, some spacers break if your have 250hp+ to the rear wheels. They are safe for front wheels so i recomment at least a 25mm front.
Extended stud is just as safe but if to much weight/stress is put on them they will snap.
Old Jun 4, 2005 | 02:25 PM
ConceptS14's Avatar
it would depend on how thick you want the spacer to be.
over 20mm and you'd have to use the adapter style.
up to 20mm, nismo 60mm studs will work.
5mm or less and you'll be ok with stock studs
Old Jun 4, 2005 | 02:28 PM
^ i think i said that plus more.
you gave no real info.
Old Jun 5, 2005 | 01:10 PM
JDMxDrift's Avatar
Is Kyo-ei a reputable company. They make the bolt on spacers. If i was going w/ extended studs i was gonna go with H&R. What ya think?
Old Jun 5, 2005 | 06:02 PM
never heard of kyo-ei
Old Jun 6, 2005 | 07:35 PM
silviadriver's Avatar
go with kics spacer. never go ext studs and a fat clunk of spacer.
go tiwth an adapter that is hubcentric and if possible wheel centric as well.
Old Jun 7, 2005 | 12:55 PM
JDMxDrift's Avatar
Would you explain why to stay away from studs and a spacer. Its not because i don't believe, but to see if there is evident reasoning.
Old Jun 7, 2005 | 01:32 PM
Raiten's Avatar
You can get the Kyo-Ei spacers from Project Nissan $15.20 a piece, going from 3MM, 5MM, 8MM and 10MM.
Project Nissan has these wheel hub centric rings....is this what you were talking about?
Old Jun 7, 2005 | 07:49 PM
yes hubcentric rings. or you can get an adapter made that is hubcentric already no rings.
if you get ext studs and a spacer, a fat clunk of it and isnt hubcentric, the load is placed more on the studs and can break
avoid it by getting an adapter. with an adapter the load isnt on the studs more on the hub "lip"
Old Jun 7, 2005 | 08:00 PM
ConceptS14's Avatar
no you didnt.
yes i did
Old Jun 7, 2005 | 08:19 PM
and if youre getting the adapter type spacers anyways...u can get the 4-5 lug conversion easy...lol...if these are for your type x rims then its kinda pointess tho huh...
Old Jun 7, 2005 | 08:54 PM
whoa! Type X rims!? carzy!
Old Jun 7, 2005 | 09:59 PM
JDMxDrift's Avatar
Old Jun 7, 2005 | 10:41 PM
JDMxDrift's Avatar
With the bolt up adapter style, do i still need it to be hub centric? It seems that all hub centric does is make the inside diameter the same as the hub, which is ~66mm so that its centered. But if the bolt on ones are just bolted on, won't they be in the center?
