Wheelhop???
Old Nov 13, 2006 | 07:29 PM
positron's Avatar
Wheelhop???
You guys explained bumpsteer pretty good so what's wheelhop, what causes it and how do you fix it?
Old Nov 13, 2006 | 08:28 PM
Black240Coupe's Avatar
worn shocks usually cause wheelhop....
Old Nov 13, 2006 | 09:10 PM
positron's Avatar
How does the car behave when this occurs?
Old Nov 13, 2006 | 09:23 PM
KerosineK's Avatar
It's can also be caused by bad motor mounts/high HP motors with stock motor mounts.
Old Nov 13, 2006 | 11:10 PM
re037's Avatar
so much twisting force is being exerted on the wheels, the car itself winds up. kinda like axle wind up.
Old Nov 13, 2006 | 11:18 PM
basically have u ever launched ur car and sometime when the tires spin the rear end vibrates/jumps around..thats wheel hop...of course its opposite on FWD
fix by getting subframe spacers/more solid rear end...good shocks/springs/coilovers whatever..
ps i have coilovers and spacers and i get wheel hop quite often..thats why 240s arent the best drag cars...
Old Nov 14, 2006 | 04:52 AM
positron's Avatar
I've been researching subframe spacers. I was originally gonna have a shop do this but I think I want to slay this dragon myself. Did you guys get the subframe spacers with the slits/cuts in them or the completely whole spacers? Is there a difference in them other than ease of installation?
Old Nov 14, 2006 | 05:02 AM
positron's Avatar
Old Nov 14, 2006 | 05:18 AM
jspaeth's Avatar
Yes, big difference.....the solid ones are actual aluminum bushings....you have to drop the whole subframe and press out the old bushings to put these in....
I think most people on here will tell you they are overkill....the subframe SPACERS are sufficient....they are the ones with the slits in them
If you pay someone to do it you will be pissed....it takes about 30 minutes to install them. So easy
Old Dec 14, 2006 | 03:35 PM
positron's Avatar
I installed my subframe spacers today and my wheelhop has been almost elimanated. There was a very big difference in the rear end performance and it feels a lot more solid than before. The only trade-off is the extra noise...CLANK, CLANK, CLANK!!! Oh well!
Old Dec 14, 2006 | 03:39 PM
positron's Avatar
Yes indeed if you pay someone to install the spacers you will be majorly pissed. This was one of the easiest installs I've done to date and I'm just a weekend shadetree mechanic. It would have taken me about twenty minutes start to finish if I hadn't stopped to take pictures.
Old Dec 14, 2006 | 08:06 PM
congratulations you seem pretty psyched about doint it yourself.
Old Dec 14, 2006 | 09:29 PM
epp_b's Avatar
Wheel-hop only seems to happen to me when it's really slippery (ie: ice/snow)
Old Jan 7, 2007 | 07:09 AM
positron's Avatar
Put my rear swaybar back on, changed out the traction control links, rear toe rods and subframe spacers. It has helped to minized the wheelhop considerably. I think after I change some more rear suspension parts and do an alignment, I have it at a minimal level.
Old Jan 7, 2007 | 10:58 AM
accually i had a clank then i put the spacers in and my clank went away
