who here has actually fixed your rear camber
Old Jul 5, 2003 | 07:26 PM
Jonas's Avatar
who here has fixed your rear camber?? because the camber is actually not starting to make its effect. for the front iam thinking about those nopi camber bolts, any one had any experience with those?? they claim that it fixes about 1.75 deg of camber. as for the rears i was looking at pdm racing and saw these and i wonder if they will fix my camber well enough to somewhat properly eat up my tires.
Rear 1989-1994 S13 OEM Nissan Upper Control arm with SPF1638K poly bushings installed.
how much camber will that fix?
Old Jul 5, 2003 | 11:03 PM
Jonas's Avatar
hrmm anyone know how i can modify the stock to be adjustable
Attached Thumbnails who here has actually fixed your rear camber-how-can-i-do-.jpg
Old Jul 6, 2003 | 11:07 AM
barrigaS14's Avatar
i have adjustable rear parts for my car and it fixed it fine. go to
http://www.phase2motortrend.com/phas...uspension.html
and get the battle verison stuff. great product. i have the upper control arms and rear toe links. i am going to get the forward links and front t/c cars once i buy my new engine. then after that nismo stuff.
Old Jul 6, 2003 | 12:45 PM
Jonas's Avatar
yeah i was thinking of a way to modify the stock upper arm to make it adjustable, because i dont want to spend 500 on upper arms.
Old Jul 8, 2003 | 09:29 PM
barrigaS14's Avatar
its only 300 for the arms. and i would think of you not wanting to do that to your arms. you might break them at a very bad time. check the bolts to the Toe arm and the Control arm (going away from the brakes) there are adjustments on those bolts that you can pull in toe/camber.
Old Jul 8, 2003 | 10:31 PM
rudeboy's Avatar
you can slot your rear upper arms to give you a little adjustability...no safe if yu slot too much
the eccentric bushings will do some justice.....buy those if you are on a tight budget
Old Jul 28, 2003 | 01:11 AM
SHIFT_Lock's Avatar
Re: who here has actually fixed your rear camber
if you look at the image that peice does nothing for camber.
a camber bushing has a offcenter shank in the middle.
i just did a rite up of the bushing change over.
http://www.club240.com/forums/showth...&threadid=4972
i'm trying to rember who made the full set . they are yello. i gotta look that up.
Old Jul 28, 2003 | 03:21 AM
StanBo's Avatar
The yellow set is from pdm as well.
Have you guys tried to fix your camber with an alignment before getting these parts?
How much are your cars dropped?
Old Jul 28, 2003 | 10:09 AM
SHIFT_Lock's Avatar
thats them..i think you just buy 2 sets and it is a full set then if i recall correctly.
Old Jul 28, 2003 | 02:48 PM
StanBo's Avatar
It matters how much camber you have to fix. But you will not know that without an alignment. Drop the car. Get it aligned. Find out how much you can fix. Then resolve the problems.
Old Jul 28, 2003 | 10:28 PM
SHIFT_Lock's Avatar
true true.
Old Jul 29, 2003 | 03:20 AM
StanBo's Avatar
Originally posted by SHIFT_Lock
true true.
I run zero and -2 in the rear without camber plates or arms in my car. I am also currently running about a healty 2 inch drop. I used to run a 4 and it was poo.
jspaeth
Apr 2, 2006 10:01 PM
Waynehead05
Jul 27, 2005 12:05 PM
ivanthieme
Apr 17, 2005 07:33 PM
StanBo
Oct 1, 2002 08:26 AM
BobTheSlob
Sep 26, 2002 09:28 PM
