Will it fit?!?!
Old Nov 5, 2005 | 11:08 PM
SoMack's Avatar
wat series of tire should i get?? like how thick?
Old Nov 5, 2005 | 11:21 PM
SoMack's Avatar
anyone got a picture of those sizes on a car??
Old Nov 6, 2005 | 09:09 AM
borrowed from DaPCwiz again
this is 16x8 +20 with a 5mm spacer, so it sits like a +15. +10 will stick out just a tad more, and s13 fenders are a little narrower, so they will look pretty nice. i would say 205-215/50 or 205-215/55 tires. you might need to roll fenders if you get like a 225 or larger. someone else can chime in.
Old Nov 6, 2005 | 10:40 AM
SoMack's Avatar
ok thanks dude good thing i asked before i bought...my car would of looked fu**ed
Old Nov 8, 2005 | 06:06 PM
BigVinnie's Avatar
It will be fuc$ed on yours though you have an 89 240 not the 95 and above. Wheel wells and housing are wider on the 95 and above. It will stick out like a sore thumb on the s13 chassis's...
Old Nov 8, 2005 | 06:18 PM
people tuck 17x10+30 in the rears of s13's on stock fenders that have been rolled and pulled slightly if any at all. the difference is maybe 15mm at most between s13/14 fenders. 17x9 +20 is really easy to fit on s13/14, so with 8" a +10 will sit about the same, probably slightly more sunken.
Old Nov 8, 2005 | 08:11 PM
Catharsis's Avatar
exactly!
i like you
Old Nov 9, 2005 | 07:56 PM
SoMack's Avatar
one more question.....wat is da hole pattern on the 89 240sx...
4h x???
Old Nov 9, 2005 | 08:58 PM
JVD's Avatar
JVD
Coming from a guy with what?... 17 x 8 +35 wheels?
And SoMack 4 x 114.3 <--- the only available bolt pattern for rota grid AFAIK.
JVD.
Old Nov 9, 2005 | 10:01 PM
BigVinnie's Avatar
JVD.
Did I read something wrong?????
this is 16x8 +20 with a 5mm spacer, so it sits like a +15. +10 will stick out just a tad more, and s13 fenders are a little narrower, i would say 205-215/50 or 205-215/55 tires. you might need to roll fenders if you get like a 225 or larger. [/B]
EDIT: It is the larger "bulkier" tire sizes that you use with the 16's rather than the 17's, along with the rim offset. Do you know how small my tires are??? (215/45) I also have a 1.8" drop, and will probably only get a little under 1 more inch of drop with that specific size before digging into the wheel wells.........
I can take some close up's for you if you would like......LOL
For that rim I would suggest 215/55. 225 would probably flare to much (beyond the wheel well), it will stick out like a sore thumb.....
Does that make sence?????
Old Nov 10, 2005 | 12:46 PM
  #26
it makes senSe because you just restated what i had posted
Old Nov 10, 2005 | 03:29 PM
  #27
BigVinnie's Avatar
It was more of a refrence for JVD, and yes I did take what you quoted.......LOL
BobTheSlob
Sep 26, 2002 09:28 PM
rbboyl
Sep 21, 2002 02:23 AM
rudeboy
Sep 20, 2002 04:31 PM
trickedout
Jun 15, 2002 05:57 PM
Condom_Sense
Mar 12, 2002 07:55 AM
