Z32 rear emergency brake
Hey guys, I have z32 calipers in the front and wanted a matching z32 in the back also. BUt i've heard the hand brake function won't work without the hub. Is there anyway to do a hidraulic handbrake like the 240sx on the z32 calipers or my only option is the hub. NOTE. i already have s14 5 lug hubs.
The ebrake is separate from the caliper. In order to have a working ebrake, you'll need to take off your rear hubs and install the backing plate with the ebrake assembly. then you'll need to find the proper ebrake cables in order to use your ebrake. For S13s Z32 2+2 work, so do the TTs, but yoiu need to reroute through subframe. For S14s, youll need R33 cables for bolt on usage,
rancidnsx
Sep 27, 2006 02:16 PM
nissans13
Aug 23, 2006 02:54 PM
silviadriver
Mar 2, 2005 08:15 PM
