boost prob
Old Dec 18, 2003 | 11:31 AM
joe3180's Avatar
boost prob
lets see if anyone has any sugestions. i have a sr20det, rsr exhust system, no cat, stock everything else. this is what happens.... at full throtle the boost pressure reaches 3 with no prob but when it gets to 5-6 it suddenly drops and then regains back to 5-6 and drops again and so on. now i think it might be my bov. anyone have any other ideas? right now im still saveing the money to buy a new one but i wanna make sure that is the prob. thanx for any help.
Old Dec 18, 2003 | 02:05 PM
Well stock boost is like 7psi...ur not far from it. Your are probably hitting the boost limit its set at...so yea,
Old Dec 26, 2003 | 06:01 PM
ftrs13's Avatar
it sounds like a boost leak to me. check your connections and make sure that youre not leaking anywhere.
Steve
Old Dec 28, 2003 | 03:54 PM
s240r's Avatar
you BOV may be releasing prematurely, it could be openeing when it builds up too much pressue, are you running a reccurculating BOV, or bypass valve?
Old Dec 29, 2003 | 06:19 PM
Silviaspeed's Avatar
Find out what the spring is rated at inside the BOV. If the spring is only rated for X psi., and your pushing Y psi, it may be opening prematurely. It could also be an old BOV and the spring is just tired. What kind of BOV is it?
Old Jan 11, 2004 | 12:03 AM
chriswgsx's Avatar
do a pressure test. with your car NOT running take off your intake pipe from your turbo. the pressure tester needs to be home made. this is kinda ghetto, but it works. i have done it many times on my eclipse and you can use the tester down the road to make sure you are not loosing any power before a big race. the parts you will need are as follows. pvc pipe end. tire valve, 2 clamps, jb weld, 1 coupler. clamp and jb weld the pvc pipe end to the coupler. put the tire valve in the middle and jb weld it in. put the other clamp on the other end of the coupler. that is all it takes to make the tester. (mine is identical and i test to 30 psi on my eclipse and it holds together!!!) using the clamp, clamp it on to where your intake comes off of your turbo and using an air compressor put air in the tester. have someone watch your boost guage to make sure it doesn't go too high. bring the guage up to around 10-15 psi and it should hold that much boost for quite some time. if their is a leak, you should be able to hear it. if you are not sure where, some people use soapy water on the hoses and look for bubbles. like i said before this sounds kinda ghetto, but you will be asking me for advice with your girlfriend next week if you try it because you will be so impressed. it is not difficult and it works great. ghetto i know, but good luck!!!
Old Jan 11, 2004 | 09:52 AM
elks240's Avatar
could it be your waste gate not actuating properly?
and i agree make a boost leak tester its easy and worth its weight in gold
Old Jan 11, 2004 | 12:38 PM
chriswgsx's Avatar
hell yeah it is elks240. i don't know where i would be without mine. i found and fixed a boost leak on my eclipse and dropped my 1/4 mile time by 8 tenths of a second!!!
Old Jan 11, 2004 | 01:18 PM
elks240's Avatar
nice i just tested mine uesterday and there is a leak but i gotta pinpoint it today and fix it
Old Jan 11, 2004 | 10:46 PM
chriswgsx's Avatar
good luck. just remember jb weld isn't pretty, but it kiks ***. holds 30 psi also!!!
Old Jan 11, 2004 | 11:52 PM
OWU Joe's Avatar
haha, funny quote Chris. Thats a pretty good idea you have there with the pressure tester. Any pictures of YOUR setup? Im curious to see what this looks like exactly.
thanks,
Joe
Old Jan 12, 2004 | 09:26 PM
chriswgsx's Avatar
no i don't. i don't have a digital camera, but it is easy to make. just put the tire valve in the middle of the pvc pipe end and put it together tight so you can put it on your turbo. it really is as simple as it sounds. you should also have a mechanical boost guage to watch. if you don't, don't hold the air hose on the tester for longer than 15-20 seconds. sorry for no pics, but im a little behind the times.
Old Jan 15, 2004 | 09:02 AM
element's Avatar
hey chris, you should do a writeup of the pressure tester.
i'd like to know how to make one as well, from what you tell us, it's kind of hard to visualize what you are talking about.
so...... please post pics when you can!
Old Jan 15, 2004 | 12:24 PM
elks240's Avatar
it is easy all you need is 3-6" pvc pipe a cap for it a valve stem, some type of plumbers glue,liquid cement or somethin like that and a coupler that will fit the intake pipe and the pvc pipe where your filter is.
drill a hole in the top of the cap put the valve stem through it where it sticks out the top glue it in place so it doesnt leak
glue up the end of the pvc pipe, stick it in the cap and let it set and cure. put the coupler on with hose clamps pull your filter put it on the pipe hose clamp it fill with air to your boost levels maybe a lb or 2 more and listen for leaks
there ya go it is real easy
if ya wanna get fancy get a pressure gauge and install it in the cap the same way you do you valve stem and voila you can watch the pressure rise right there
does that help
Old Jan 15, 2004 | 04:07 PM
chriswgsx's Avatar
im surprized that someone else knows how to make one. if you have a digital camera you could show some pictures, but i don't. but to everyone else, it is just as easy as it sounds.
