Change in "stock boost" on S14 sr20det
Old Jul 3, 2006 | 05:10 PM
KuhnDawg's Avatar
I was wonder what happens to stock boost once you modify a car. In my situation I am having lots of problems tunning my profec B spec II on my S14 SR20det (w/ stock t28 roller bearing turbo) for 12psi. I have the boost controller hooked up correctly, but it doesnt matter what I try I cannot get the car to boost below 14psi at WOT (even with the gain at zero and the SET well below 15%), hence my question: Will a high flow intake, larger MAF, and full exhaust change your "stock boost" and make it 14psi? Or is there something I'm not thinking of? Could the unit just be deffective/ not functioning properly? Anything will help.
Old Jul 3, 2006 | 05:13 PM
the have the same turbo and the same boost contraller and i dont have any problems running 9-10 psi on low boost. ill get you my settings in a little bit
Old Jul 4, 2006 | 08:39 AM
KuhnDawg's Avatar
i'd appreciate that
Old Jul 7, 2006 | 06:05 PM
sorry it took so long, i got busy and forgot about it. My mods are diff though so you may need to make some adjustments..
for 10psi
Set: 25% , Gain: 15% , Set Gain: 80 , Warning: 100 , L.: 5%
for 16psi
Set: 50% , Gain: 35% , Set Gain: 160 , Warning: 170 , L.: 5%
hope that helps ya some..
don
Feb 18, 2011 11:15 AM
AZdrifterS13
Jan 13, 2007 01:32 PM
darius
Oct 26, 2006 07:46 PM
b0rdin4life
Feb 14, 2006 10:53 PM
