custom turbo
Old May 8, 2004 | 03:49 PM
IanS13's Avatar
custom turbo
hello hi to all am new to the forums, but now new to nissans an the ka i love the 240sx my dad and my brother both have 92 s40sx i just fliped my svt contour , so i got a 92 240sx SE, my first mod is going to be turbo. i want to do a custom turbo build up can you guys help me out i need to know what all i need to buy for this kit, other than the intercooler and pipeing am going to be making all the pipeing my self that includes the intercooler pipe down pipe and exhaust system.
i never installed a turbo before but i know how they work i just need to know how to get it to work on the ka motor.
Old May 11, 2004 | 04:16 PM
BoogiepopJDM's Avatar
Dang so many views but no reply, i dont know much about custom turbos. as far as custom turbo you can find all the correct pieces you need at ebay but be xtermely careful when purchasing. you might need a piggyback like greddys e-Manage. im thinking about the same thing in the future itll give you a hella of alot more hp than a sr20det because of the ka's 2.4L. if your going to do this take a look at what products companies are using for the installation for a turbo on the 240sx, what i mean by that is to look at what turbo companies are using like if its a td06 or something else the and make sure you get an exhaust manifold that can nicelt bolt on the turbo do the research . im still researching. i dont know if i can help you any further. Good luck
Peace
Old May 11, 2004 | 04:49 PM
sorry E- manage is only for obdII s14 97-98
Old May 12, 2004 | 05:22 AM
Romeyo07's Avatar
I'll make it short and sweet.
-Find your overall power goals
-Search for more information on what all goes into a turbo system
-Research what turbo will hit your goal
-Figure your budget and shop around
-Ask if you have questions.
Old May 12, 2004 | 05:36 AM
Sil40_Mayhem's Avatar
Romey put up some good points. only things i'll add would be the turbo manifold flanged for ur particular turbo application (obviously), turbo oil feed and return lines, and maybe some guages to keep an eye on things (boost and oil pressures, a/f ratio, water temp...).
Old May 12, 2004 | 12:20 PM
Bunta's Avatar
Re: custom turbo
Originally posted by IanS13
... i just fliped my svt contour ....
how did you manage to flip your svt contour???? Your the 4th person I've heard of that has flipped their SVT contour. Has Ford done it again and built a real winner with the contour....or whats goin on here? I dont think I know anyone who HASNT flipped/rolled their contour.
Old May 12, 2004 | 12:43 PM
WingsofWar's Avatar
building own turbo kit? iv built my own turbo kits since i started owning nissans. First Off, buy ApexI SAFC, hacked or Z32 MAF, 370cc or higher injectors. You need hotpipe, downpipe, manifold, IC piping, oil feed lines, i recommned better fuel pump (Walbro 255LBS pump), water, air/fuel, boost guages. Possibly even a deltagate/tial 35mm. Retard the timing, and your all set. I wouldnt reccomend boosting it though on stock internals. If you plan on making it run more efficently purchase a wideband o2 system. have fun
Old May 12, 2004 | 05:30 PM
IanS13's Avatar
Re: Re: custom turbo
my contour was preaty fast about 190+ to the wheels i was doing about 90 when some jack *** slamed his brakes and i had to try to evade him that was a bad idea i over steered to the left so i had to correct it when i did that it was all over i hit him and he pushed my car till it fliped over and rolled few times.
so now am dumping 6 grand in this 240sx i got a lot of stuff for it already i just need to know were it all goes.
Old May 12, 2004 | 10:23 PM
specialk22's Avatar
If you plan to search for a turbo, the best bet is to learn how to read compressor maps and it will help you find which turbo is most efficient for your car and what hp you're looking for. I learned how to read them from "Maximum Boost" (great turbo book). Also for the turbine, try to find a split inlet housing turbine because they are designed for smaller cylinder engines.
Old May 26, 2004 | 05:56 AM
adavib's Avatar
I am currently in the process of building my custom turbo kit. i don't, by the way, the Greddy E-manage can work on OBD-I as long as you specify when you order from Greddy. At least that i what I think, the only reason people think they are for OBD-II is because of the recently released Greddy trubo kit that utalizes the E-manage for 96 and up 240s. That is what I was planning on going with, if not you can get the JWT ECU with a SAFC and you will be ready to go. If you get the JWT ECU then you can buy the 93 Cobra MAFS and JWT will program the ECU and send you a harness for the cobra MAFS
WhoDiddy
Feb 2, 2006 07:45 PM
asr702
Feb 27, 2004 01:17 PM
ryan15
Feb 4, 2004 04:47 PM
allen
Sep 3, 2003 06:46 PM
RNN14
Mar 4, 2002 02:19 PM
