Help with 300ZX Turbo Setup.
Old Mar 26, 2006 | 09:44 PM
TheAs1anKid's Avatar
Ok guys , im thinking about turboing my 95' KA24DE in my 92' 240sx.
I have the Following Parts.
- Tial BOV
- T25 300ZX Turbo with internal Wastegate
- Spearco FMIC ( not that big but i think it would be better than a stock sidemount)
-SR20DET Fuel Injectors off of a BlackTop
I understand that i would need to get a manifold for the turbo , and then piping for everything , after all that would there be anything else that i need in order to get this running right? i was planning on only running like 7 Pounds of boost , just enough to get a better kick out of my 240 , my engine has around 70 k Miles on it and the engine does not leak any oil anywhere.
I also understand that i will have to reroute my battery to my trunk...hmm it sounds like it would be hard , does anyone have any experience with this setup or knows someone who has done this any help or tips would greatly be apreciated thank you all.
Old Mar 26, 2006 | 11:59 PM
Helghast's Avatar
How about tuning?
ECU Retune .. SAFC .. Megasquirt?
there's a lot more than just sticking a turbo in a KA.
+ once you turbo, it'll be a project car and it'll give you headaches left and right.
Battery Relocating is cake, you can buy kits for cryingoutloud.
Summitracing.com
Old Mar 27, 2006 | 06:31 AM
there is a shop around here www.xatracing.com that will reflash my ECU , but from what im told it wouldnt be too bad of a drive without rom tuning. the SAFC is going to be expensive..... but does anyone by chance know what the TIAL BOV sounds like? i have it and i was hoping it would be quite.
Old Mar 27, 2006 | 03:38 PM
chiroke's Avatar
u do not have to move ur battery it can stay wher eit is
Old Mar 27, 2006 | 08:02 PM
88eyeguy's Avatar
Your spending hundreds, if not thousands, of dollars on the turbo setup, but you won't spend an extra 200 on an safc. I can't believe how many people have been trying to skimp on fuel management. On a budget setup, the single most important component is fuel management. The idea of a budget setup is to spend the least amount reasonable for a turbo setup, while maintaining engine reliability so you aren't forced to spend gobs of cash you don't have on a rebuild. Fuel management is a MUST.
Old Mar 27, 2006 | 08:21 PM
well i acquired all these parts from friends, the s-afc, is it easy to tune or do i have to get someone to tune it for me?
Old Mar 27, 2006 | 08:41 PM
88eyeguy's Avatar
Just take the car to a dyno and have the shop tune it with a wideband.
Old Mar 30, 2006 | 08:16 AM
just take it to xatracing for your tuning and ask them questions if they are local, those guys know 240's better than i do my own hand..
Old Mar 31, 2006 | 07:42 AM
ok, but now that i see my friends cars their 240s run into alot of problems. and Problems involve money so i found a deal a Pacesetter header for 100 dollars , im goin to prolly just install that and run it and save up for awhile for the SR swap or something. right now i have stock header with the cat then custom 2.5" all the way back to a Apexi N1 n/a Muffler. should i get a test pipe or just take the cat out and run tubing from there back. I dont want the Honda Noise , someone told me to do 3" header back... but i dont think my muffler would be good for that , any suggestions?
Old Apr 1, 2006 | 01:04 AM
Suprawoman's Avatar
The safc is really easy to tune. It took less than an hour to dyno tune my supra with the safc-II. And it is a must to tune your car. My car was running stupid rich that when we were tuning it, the fuel had a negative 19 correction factor....THAT IS HUGE!!! I regained 90 rwhp that was lost from my mods. But I would suggest taking it to a shop and having them do it if you are not familiar with saftey zones (a/f ratios etc.)
The tial bov is not loud, but also depends on where you are going to place it.
trickd240
Jun 21, 2006 02:31 PM
trickd240
Jun 20, 2006 08:48 AM
Monkey Force
Jun 18, 2003 11:26 AM
yiaracer
May 14, 2003 12:11 AM
240SX
Jan 23, 2003 08:41 PM
