Help tracing boost leak?
Old May 5, 2006 | 05:46 PM
Gearhead_42's Avatar
Unhappy Help tracing boost leak?
Edit: NVM! built one of the "Lowes Special" boost leak testers as seen on various forums... Done and Done!
How does a one man show with no dyno trace a boost leak?
Took my first drive in the S13, and while it boosts and holds boost well, there's an obvious whistle that sounds (to my inexperienced ears) like a small diameter (so high pitched) leak under boost. Can I assume that the leak will be present under vacuum as well and try the starting fluid "spray at the joints" test?
Thanks for any help you can offer!
Oh yeah, for details: stock s13 turbo, Blitz DD BOV with an unbranched line from the TB, recirculating to the stock intake rubber pipe, wastegate lie T's to the FPR and the boost gauge, TurboXS manual boost controller; FMIC with silicone couplers from the hot pipe on, stock elbows on the hot pipe.
slidewithpride
Aug 12, 2011 09:51 AM
AZdrifterS13
Jan 13, 2007 01:32 PM
yektik99
Jul 17, 2006 10:46 AM
b0rdin4life
Feb 14, 2006 10:53 PM
Evi| S|3
Dec 31, 2003 09:29 AM
