I have a 1992 240SE could I use the turbo from a CA18
Old Mar 21, 2005 | 04:19 AM
Silvia_Freak's Avatar
Question I have a 1992 240SE could I use the turbo from a CA18
I know this guy which is selling a CA18. Most likely its broken. So I was wondering If its possible to use the CA18 Turbo which is still good. I have a Ka24. Would that be a direct fit? Or would I half to custom modify? Thanks
Old Mar 21, 2005 | 05:59 AM
drnovascotia's Avatar
if it is a CA18DET that came in 240sx's uses the same engine mounts and such, although some work for wiring and such is needed, same as a SR swap.
Check NICO for more information.
Dr.
Old Mar 21, 2005 | 12:21 PM
4984 5fsdskfvjdsntr4's Avatar
Banned
if ur talkin about swapping the engine then it will fit like drnovascotia said.
if ur talkin about only using the turbo, then i wouldn't, if it is the stock ca18det turbo.
a t25 from the ca is too small for the ka24. if it is a t25g from an sr20 (sometimes found on ca's) then it will work but i would recomend a t28, or t3/t4. Also for any of these u would need a different manifold.
Old Mar 21, 2005 | 03:23 PM
IM going to go ahead and buy the motor. IT has about 50k is what the guy said. MOtor, trans, ECU and wireharness, and turbo. Do I need to buy mounts or is this direct fit. Are there any links to how to do this swap? Or I mean is it possible bolt on. IS this swap good because im buying the motor for 600$ Cant afford SR20.
Old Mar 21, 2005 | 04:09 PM
ArticDragon's Avatar
The CA is a great motor, It should fit right in, Chek NICO and this CA section to have your questions answered.
Old Mar 22, 2005 | 09:14 PM
Catharsis's Avatar
CA turbo is soo small its not even a t25 its a t22 not worth the time to fit it to a ka
Old Mar 22, 2005 | 10:28 PM
Krazyballa3's Avatar
50 k miles on a CA18 i thought those were ancient
Old Mar 23, 2005 | 08:23 PM
Catharsis's Avatar
they are old
Urban Outlaw
Sep 16, 2007 07:52 PM
auburnchris
Dec 31, 2005 06:35 AM
Silvia_Freak
Mar 21, 2005 09:34 AM
Ricky240sx
Jan 27, 2004 05:39 PM
neo84
Jun 30, 2003 12:25 AM
