My turbo manifold is loose is this norm??
Old Nov 2, 2005 | 04:45 PM
colombia's Avatar
i took my turbo manifold off to check why i was able to move the turbo with my hand and when i took it off i discovered that the top portion of my turbo manifold is loose, there are some sort of plates holding on to the screws in place. It doesnt make any sence to me why it would have any play thanx for ur help
frank
Old Nov 2, 2005 | 05:36 PM
Helghast's Avatar
It shouldn't have any play at all.
Tighten those bolts..and make sure use Grade 10's. Turbo's get way too hot for stock bolts.
Old Nov 2, 2005 | 05:59 PM
nsn240's Avatar
are you kidding me? common sense, no a loose manifold isnt good... tighten the bolts and put it back on
Old Nov 2, 2005 | 11:42 PM
Catharsis's Avatar
orst thread ever
Old Nov 3, 2005 | 12:51 PM
colombia's Avatar
ok thanx will do
sorry guys im new
Old Nov 3, 2005 | 06:01 PM
2fast4y0u's Avatar
you can also use a lock tite if you need to. make sure its rated to high temps
i had the same problem after i put an aftermarket manifold on.
Old Nov 3, 2005 | 10:25 PM
twofourtyesex's Avatar
Banned
honestly i thought this was a joke when i saw the thread. had to check.
Old Nov 5, 2005 | 07:31 AM
Initial Daniel's Avatar
A: No.
b0rdin4life
Mar 10, 2006 08:05 PM
vbgambini
Jan 22, 2006 03:32 AM
wasaabi4784
Dec 6, 2005 08:10 AM
BarnDog296
Aug 17, 2005 05:52 AM
darook
Jul 11, 2005 07:40 AM
