Nitrous
Nitrous
I'm not sure if this is the right place to post but I want some information on sr20s and nitrous.
I am planning on putting a 100 shot direct port on my s14 sr20 motor on the stock turbo and bolt ons with around 12-15 psi.
stock injectors and a walbro 255
ANY IDEAS OR SUGGESTIONS??
PLEASE ONLY REPLY IF YOUR A. EDUCATED ABOUT NITROUS OR B. HAVE EXPERIENCED NITROUS ON A 240 BEFORE THANKS
I have never experienced nitrous on a 240 before, but I have had experience with it on other vehicles. IMO, it is the biggest bang for the buck. A 100 shot would definitely hit hard and fast.
Make sure you read up on it so you dont blow yourself up though.
just do it so u can post up in a few weeks how its a bad idea cuz u blew ur motor, that way no one else will have this problem... go post on www.zilvia.net where u are going to get more attention to this thread and see what they have to say, i garuntee its the same thing..
thanks for the first post. but for the second post why are you so stubborn i told you not to post unless you had experience, you know NOTHING ABOUT NITROUS and when nitrous is done right it is just as safe as higher boost or even a supercharger
THANKS
THANKS
im curious, sounds like a far out plan..but i think it should be interesting.
i think someone said stock bottom end on an sr is like 350-400hp idk tho dont quote me on that.
I thnik you MAY BE ok on this, but like i said dont rest on what i say..i still have a KA24 under my hood
100hp direct port..... on a stock motor...... 12-15psi...... You are over loading the motor w/ oxygen effectively raising cylinder pressure....... a lot...... I wouldn't suggest it........ my suggestion is do a lot more research. Ive done and seen a crap load of imports w/ nitrous..... probably not a good idea homey.....
they say 50-75 shot is your safe point. i still burned up my rings with a 50 shot. but i had it set up at the gas peddle so i had it every gear and i was very happy with it. but with that high of boost i wouldnt do over a 35 shot untill you upgrade the valvetrain, rods, forged pistons and head gasket. and also p&p that head for more air flow would help a lot. i would always run forged pistons for that big of a shot of nitrous
who "says" that and when you burned your rings with the fifty shot did you retard the timing, any tuning, size injectors? and was it a direct port or a dry shot it was probably a dry shot!
thanks
thanks
thanks
thanks
edit, also i had ngk copper plugs because you know platnuim plugs dont mix with nitrous
