Nitrous
Old Nov 26, 2006 | 08:27 PM
v8killa's Avatar
thanks for the input but thats very interesting what type of gas and did you have any way to see your a/f ratio like a wideband??
Cause everyone who I spoke to especially a tuner who is on all the turbo street magazines said sr's can take anything you throw at it with the right tuning up to about 400-450 wheel and i only want around 380whp so i guess time will tell!
(just waiting on a flywheel and a clutch and I'm off to get it tuned)
HOPEFULLY ILL POST SOME NUMBERS!!!
thanks again for the input
Old Nov 26, 2006 | 08:35 PM
nick3's Avatar
i always ran 93 here in Tn, my car didnt run well on anything else. i didnt have a wideband but i had a air/fuel ratio gauge. you can say i just abused it.
Old Nov 26, 2006 | 08:56 PM
v8killa's Avatar
theres the answer right there if you didnt have a wideband or an accurate way to tell if you were running lean or rich than thats what fried your rings!
thanks anyway for the help!
Old Nov 27, 2006 | 03:56 AM
nick3's Avatar
ride revolution installed the nitrous kit, the dyno tuned the car when they installed it and got the air/fuel correct. and your welcome
Old Dec 5, 2006 | 04:17 PM
silentvoice19's Avatar
ok im not tryin to be an *** but you are going to blow up your car. If that motor has high miles you screwed more.Yes its all in the tuning but, when you putting more air in with that turbo and putting even more air in with that nitrous oxied its gonna over load the cylinder and i got money on it your tune wont be right.Somethin is gonna hickup or skip that time you go to hit the button and well see you on here selling another blown sr20det motor.Like i said in not tryin to be a ***.If i was you i would spend that money on a t28 Hks waste gate headers some good stuff.Good luck
Old Dec 5, 2006 | 04:52 PM
v8killa's Avatar
I have no patience left replying to people who are asked to only be educated. And you obviously have no education when it comes to nitrous.
SO THANKS FOR YOUR INPUT BUT YOU ARE TOTALLY WRONG!!!!
Old Oct 24, 2007 | 02:01 PM
v8killa's Avatar
Just Wanted To Let You Guys Now That I Built My Motor Because Of A Bad Oil Pump Before I Even Tried The Nos But Heres The New Mod List!!
Cp Pistons
Eagle Rods
P&p Head
Decked Block
New Freeze Plugs, Bearings, Seals
New Oil Pump, Water Pump, Timing Chain Kit!
Arp Studs
Pe Head Gasket
Bc Cams, Retainers, And Springs
Rocker Arm Stoppers
Direct Port Nos System 100 Shot (with Heater, Prog Controller!!)
T28 Turbo ( Custom Rebuilt With Gt28r Comp Wheel In It)
3" Dp With Open Exhaust
550cc Sti Side Feed Injectors With Stock Rail
Walbro 255 Hp Fuel Pump
Z32 Maf
Safc Ii
Greddy Intercooler & Piping
Koyo Radiator With Samco Hoses
Spec D Clutch Kit
Z32 Rear Vlsd
Z32 Oem Turbo Wheels 225 F Tires, 245 R Tires
25mm Spacer All Around
Ill Keep You Guys Updated I Know I Can Make Around 450+whp With This Setup But Ill Prob Run Low Boost With The Nos And Be Happy With 400 Whp!!
Ill Post Pics If You Guys Want
Old Oct 24, 2007 | 02:47 PM
clubredsilvia's Avatar
^^^please do.
Old Nov 9, 2007 | 06:17 AM
240SS's Avatar
gonna be maxing that SAFC 2 out with those 550s. Unless you have a rom tune.
Old Nov 9, 2007 | 06:50 AM
v8killa's Avatar
not goin with the nitrous anymore thanks
Old Nov 9, 2007 | 07:47 AM
  #26
k_wakasugi's Avatar
What made you change your mind?
Old Nov 9, 2007 | 07:58 PM
  #27
240SS's Avatar
lol this kid is a trip. Nitrous is a good thing but you better have a good setup and a way to control timing. The SAFC will advance the timing using such larger injectors.
A window box nitrous setup, big fuel pump, wet kit and a MSD ignition box would probably be needed to run it correctly. Unless you could step up to a AMS so you can control the timing.
altima/240sx
Sep 4, 2003 03:10 PM
240duffman
Jul 17, 2003 06:31 PM
altima/240sx
Jan 10, 2003 02:23 PM
redrocket
Jun 19, 2002 10:30 AM
ni*2*ss*4*an*0*
Feb 20, 2002 09:28 AM
