Possibe Uh-Oh on compression!
Old Mar 25, 2007 | 02:37 PM
I did a compression test today on my 100k mile KA24de in preparation for turboing it and came across a possible problem. I dry tested it and the results were about 150psi across all 4 cylinders. Is this too low to turbo?Should I look into this or just assume that the gauge isnt accurate, since the results were solid across all 4 cylinders?
Old Mar 25, 2007 | 03:15 PM
did you you let the engine reach normal operating temp. just curios because if you didn't you could get low reading when checking compression and doing a leak down test.
Old Mar 25, 2007 | 03:17 PM
the trick to see if its blown rings is to drop a few Table spoons of oil in the cly that you are checking, if the psi goes up,, they are gone up bro..
warming is cool but not needed. since this method can be used to check a motor in the junkyard with no way or warming.. it is also the method used by importers ( should be) of engines
psi levels
standard 179 @ 300rpm
minimum 151 @ 300 rpm
Old Mar 25, 2007 | 03:20 PM
Yeah, the car was all warmed up. If it is the rings i assume I will have to replace the rings before turboing it?
Old Mar 25, 2007 | 03:23 PM
in that case do the rings forged pisons and rods
Old Mar 25, 2007 | 03:27 PM
X1000
stuff is much affordable bro.
Old Mar 25, 2007 | 03:50 PM
parts are usually cheap it's the labor that will make you go broke. that's why i do all my own work.
Old Mar 25, 2007 | 03:57 PM
sr91240's Avatar
yea if you know what your doin you can do new rods and pistons in a day theyre easy to do its just time consuming
Old Mar 25, 2007 | 04:50 PM
X2007............
yea 150 is pretty low, id replace rings before boost. lol i read 140 all across. im picking up sohc pistons soon tho and some new rings. 172000 ftw
Old Mar 25, 2007 | 05:02 PM
X2007............
ok you lost me bro.
Old Mar 25, 2007 | 05:06 PM
lol hes agreeing with you.
Old Mar 25, 2007 | 05:09 PM
well yeah but what's with the numbers?
so i could say mfwx20000000000
that's me for the win by the way.
and here we go off topic again.
Old Mar 25, 2007 | 05:23 PM
na bro its on topic lol.. it with-in helping our buddy with his compression issues lol
Old Mar 25, 2007 | 05:36 PM
silentvoice19's Avatar
what i would do if i was you head to a junk yard get yourself a ka24de from a junk 240 and rebuild that.Drive your car until it explodes
