rb20det performance quetions
Old May 26, 2004 | 12:20 AM
portion's Avatar
hey i searched but i dont think this has been covered
i asked b4 for the rb25det
but now i wanna no somethings about the rb20det
what is the max hp can u get out of a rb20det? is it more than an sr20det? was it 550 or somewhere around there for sr's
what is stock boost?
max boost on stock turbo?
which would win stock for stock
s13 rb20det or s13 sr20det?
that is all
thanks
Old May 26, 2004 | 09:55 AM
deprecated's Avatar
the rb20det came in some r31 skylines, the r32 gts-t, r32 gts4, the cefiro, the c33 laurel, etc. RB is a designation that generally means 6-cylinder, as opposed to the sr20det or the like. The rb20det stock made around 210bhp @ 6500rpm @ the fly, and around 185 lb/ft of torque at the same r's. the rb20det can make as much power as you can make it make, to put it simply. sure it displaces less than the rb25 or rb26, but you could always stroke and poke it. just do a bit of research.
Old Jun 5, 2004 | 11:02 AM
rkcarguy's Avatar
There isn't much info out there for these as far as upgrades are concerned. According to night the RB25 crank can be installed to get you a stroked RB22. Being the bore is also smaller means less force placed on the bottom end at the same boost as the Rb25, so I think more boost could actually be ran as long as you stayed within the headgaskets limits. So I think the Rb20 should hold up to as much strain in the bottom end as the RB25. I'm going to be doing this swap shortly, and I choose the RB20 because it's lighter than the RB25 and just something different-theres like 4 SR20 swaps in our town here. Plus when you are just cruising there should be actual decent gas mileage.
Old Jun 7, 2004 | 12:34 PM
xpcgamer's Avatar
I once read it is better to have a 2.0 six than a 2.0 four for turbo and pwr. Theory behind this is that it is alot harder to bang detonate a small piston than it is to a larger piston. Hence takeing 2.0 four a boreing it out. Also you can have higher piston speeds as well. I guess that is why F1 motors are V10's that only displace about 3.5 liters. I my self am saveing for a 97,98 s14 to put in a RB20.
Just a thougt.
Old Jun 15, 2004 | 02:53 PM
portion's Avatar
yea i am thinking of a rb20 myself but everytime i see a vid of a rb25 it makes me lean back to a rb25
only of it had a lot of money man!!
but i wanna be able to drift too so rb20 is a pretty good platform there.
i wonder what is the max hp anyone got out of a rb20det
not stroked or nothing jes 2.0
Jovan
Sep 6, 2005 04:38 PM
slidingsideways
Jan 19, 2004 11:46 PM
THaCoLoRReD
57
Jan 10, 2003 08:58 AM
rbboyl
Northeast
Jul 29, 2002 06:16 AM
ShaggyDawg
Feb 26, 2002 02:07 PM
