Stock T25 Wastegate/actuator question???
Old Nov 23, 2004 | 02:03 PM
TSR20's Avatar
Sorry if this is a stupid question or in the wrong topic area, but need quick help if possible. I was noticing the small vacuum hose line coming from the stock t25 wastegate/actuator was disconnected at the opposite end and I'm not sure where it supposed to plug into. Help please, i'm still a newbie on my sr20 and turbos so please forgive.............
Old Nov 24, 2004 | 01:59 PM
4984 5fsdskfvjdsntr4's Avatar
Banned
It should connect to some vacuum line on the intake. I cant tell u exactly cause i have a ca not a sr.
Just look around there should be an empty connection somewhere. Not sure but i think it goes under the TB.
Old Nov 28, 2004 | 08:17 PM
goneturbo's Avatar
It could have been connected at a few different points. maybe a vacuum slot on the intake mani, or it could have come from a port on the intake before the TB. It may have also been connected to the stock sensor/restrictor for the wastegate line. you should be boosting crazy numbers and will blow your motor if you dont connect the wastegate.
motegineon
May 9, 2006 08:28 PM
b0rdin4life
Apr 4, 2006 11:26 AM
Gearhead_42
Apr 3, 2006 03:06 PM
2fast91
Oct 7, 2004 10:59 AM
Jsquared
Aug 17, 2003 11:25 PM
