turbo oil plumbing question
Old Jul 9, 2005 | 11:40 PM
Jack0423's Avatar
Is there a way to tap the oil pan for an oil drain line without having to drop the oil pan. I'm paranoid about metal flakes in my oil pan causing a future issues with either the oil pump or main bearings. I tried the hondamethod of a sandwich plate but my oil pressure spike causing a ton of blow by at the turbo. Any ideas would be a big help.
Old Jul 10, 2005 | 12:21 AM
LA_phantom_240's Avatar
im no expert on turbo plumbing, but im pretty sure you have to drop the pan. if you do that, there shouldnt be any worries about metal shavings, as long as you clean it and put new oil in the car.
Old Jul 11, 2005 | 07:34 AM
bottombunk's Avatar
if your worried about metal shavings, dont take the lazy route. take the oil pan off. your better off doing it right the first time.
Old Jul 11, 2005 | 11:27 AM
exactly
Old Jul 30, 2005 | 08:41 AM
lowxpectationz2's Avatar
Don't take the risk, take your time and do it right the first time, so you dont have to worry about getting those chips in your motor, that would be hell on your cylender walls
SC240sx96
Aug 11, 2006 01:23 AM
trevr
Jun 3, 2005 07:45 AM
Mattyg2
Dec 20, 2004 02:58 PM
cticknor666
Oct 22, 2004 03:24 AM
