What are the basic parts need for a turbo set up?
Old Sep 30, 2004 | 07:12 PM
tallic_red240sx's Avatar
I plan on turbo'n the Ka, what would be involved to do A basic turbo setup, just things I need to get my car rollin...Down the road I want to add some xtras, but for now I just wanna get started.I have a 3" stainless exhaust coming next week, and just put A Walbro fp on A few days ago.....Help!!!
Old Sep 30, 2004 | 08:47 PM
Waynehead05's Avatar
1) search
2)search on google.
3)Search one more time... then create a new thread
Old Sep 30, 2004 | 11:48 PM
Moved to turbo forums
quick list
Turbo
Manifold to fit the turbo
Downpipe
Bigger injectors
Bigger fuel pump
Tuning program
Intercooler and piping
and a few more things
Old Oct 1, 2004 | 02:18 PM
tErbo b00st's Avatar
the only problem, is its not the basic stuff that you should be worried about. Its the little stuff like oil fittings, ect.
But yea, do some searching...its out there. I would recommened a kit, such as the Greddy Kit.
Old Oct 1, 2004 | 07:17 PM
89s13drifter's Avatar
A kit is best if you don't know how to put one together. Read "Maximum Boost" by Corky Bell and you may get deeper insight as to what you need.
Old Oct 1, 2004 | 09:24 PM
kable's Avatar
what terbo said about the little stuff. if you're asking questions like that your best bet would be to educate yourself and read read read. then you will know what you need instead of wondering and asking. that way you can assess your own problems instead of waiting for one to come up.
Old Oct 2, 2004 | 02:02 PM
So true
Old Oct 5, 2004 | 10:58 AM
Chris1casillas's Avatar
This web site really helped me out to picture it better. I read maximun boost but had a hard time picturing it all in my head. If u want to know the BASIC hardware and install here is a great site I stumbled on. I know its not for a nissan but it should be the same basic stuff
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
Old Oct 6, 2004 | 05:41 PM
slowalty's Avatar
Im gonnna build a kit with a t25,manifold,sidemount ic. barebones
do i really need a fmu? like a the on on the honda page. i do not plan on any type of ecu mod yet cause i planned on running low boost. does anybody have any input on this?
Old Oct 6, 2004 | 07:52 PM
ArticDragon's Avatar
Don't you need an ECU mod to handle the boost? I know the stock one won't manage the new settings for crap.
Old Oct 6, 2004 | 08:37 PM
slowalty's Avatar
ive heard with runnin real low boost i wont have much problems and i might try to get a safc if i can fin one cheap.
Old Oct 7, 2004 | 09:13 AM
from what I have read in the forums u can get away with 5-7 psi safely on stock, and with an fmu I have heard MAX 10-11psi
Old Oct 7, 2004 | 09:25 AM
S14Dude's Avatar
all you need is an 8:1 FMU and running 8psi you will be perfectly fine. after 8psi, you should get an ECU tuned, and maybe the S-AFC to manage that air and fuel. Also when you get the FMU, get the Z32 fuel filter. DONT forget to get that. When you run more boost, just upgrade with fuel rail, injectors, and you can get all these parts for your custom KA-T at www.boostdesigns.com
Old Oct 7, 2004 | 09:27 AM
if ur worried about ur ecu and u know about tech stuff here is a web-site that has a program that can help u to reprogram ur computer ,cus fmu's are really just band aides. (zcontrol.net) is the web-site that has the program, the program is called srtalk and is suppossed to work with any nissan 4 banger. its still in beta testing so it hasn't had all the kinks worked out from what I have heard.
TheRob
Nov 14, 2004 07:01 PM
BoogiepopJDM
May 31, 2004 11:47 AM
SpAzZy
Jan 16, 2004 09:42 AM
jtsarnak
Feb 12, 2003 02:08 PM
7mgte in a 240?
Dec 12, 2002 09:58 PM
